1991 318is diff fluid
  • immajackuup
    • Dec 2010
    • 1132
    Is this the correct diff fluid to use?
    Mobil/1 qt. 75W-90 synthetic gear oil
    http://www.autozone.com/autozone/acc...fier=1437_0_0_
    Also when putting back rear diff cover do I use alittle bit of rvt on paper gasket or just paper gasket??
  • KenC
    King of Kegstands
    • 14396
    Why are you taking the diff cover off? RTV will work if you let it cure.
    It's a little more than a quart I think. Make sure it has an LSD additive if your diff is an LSD.
    Originally posted by Gruelius
    • Holland
      • Nov 2008
      • 7178
      It will take a little more than a qt.
      Originally posted by DEV0 E30
      • ///digitalme
        • Dec 2009
        • 2088
        ^ what he said. I used redline also while you're down there change your tranny fluid. Redline mtl is a great oil to use!!!
        • immajackuup
          • Dec 2010
          • 1132
          pulling diff cover off to replace bushing with akg poly. Guess i put some honda bond on the paper gasket to make sure it seal.
          • trigtm
            • Oct 2009
            • 50
            I've replaced the diff mount bushing with the cover still on so I wouldn't take the cover off unless it was leaking and neede a reseal.
            RTV as stated works fine. Honda bond is the same material more or less.
            • jrobie79
              • Mar 2006
              • 2525
              I thought the small case LSD's were a little under a quart?
              1991 318i ---- 308K - retired
              • immajackuup
                • Dec 2010
                • 1132
                How you manage to remove diff bushing without pulling rear cover off?? Also I like honda bond over rtv because is easy to clean up.
                • harv
                  • Nov 2004
                  • 555
                  HondaBond is the shit! Been using it for years. You can also use YamaBond but I'm partial to Hondas.
                  John
                  The Revolution will not be televised.
                  • Nick_S
                    • Apr 2011
                    • 3655
                    Mine was. Just under a quart it started coming out the fill plug. And OP, I used Mobile1 75w-90LS for the LSD.
                    91 318is M50 swapped
                    05 Honda Pilot
                    24V swap thread
                    • immajackuup
                      • Dec 2010
                      • 1132
                      • lbreevesii
                        • Aug 2009
                        • 412
                        you can use a hacksaw blade to cut the outer ring of the old bushing then it will pop out easily, I did it on the workbench.
                        I don't always wreck cars, but when I do I wreck them into trees.
                        91' 318is S50 swap - The Black Widow
                        • Jaxx_
                          • Dec 2009
                          • 1880
                          torch if you really have to, but I wouldn't really want to do that with it still near the car.
                          I'm using LS 75W-140 from mobil 1. it's a bit noisy when going around turns on the street or when cold, but the lockup is solid and because of the autox I opted for a heavier weight. I'm satisfied with it, but I wouldn't recommend it for a daily or primarily street car.
                          • immajackuup
                            • Dec 2010
                            • 1132
                            then what you recommend for daily?? im still gonna pull rear casing off to put on new seal and press bushing out.
                            • Jaxx_
                              • Dec 2009
                              • 1880
                              then what you recommend it for a daily?? im still gonna pull rear casing off to put on new seal and press bushing out.
                              a lighter fluid... the 75W-90 should be fine, but if the diff chatters and is annoying you might want to put in a little friction modifier.
