This is not a difficult project and you really need to relax a bit about it. For my alternator harness there were two layers of nuts and it may at first appear that you have all of them, but look again after you remove the top wires from the mounting stud. If you are just doing the mess deletion you don't need to touch the alternator, but I am assuming you are planning a general clean up, if so you can simply bag and tape closed any areas you don't want getting wet.
Further, relax, everything will go fine, and if something does go wrong you can fix it easily enough, after all the M42 is a supremely simple car to wrench on.
