m44 swap into a m42 car?
  • Brilliantrot 318is
    • 1073
    Has anybody on R3V done a m44 swap into a m42 car? I'm asking out of curiosity.- if so please link me to your tread.. i want to know more!!
    Transaction Feedback: -click here
    [e30: '91 318is coupe|brilliantrot||e36: '98 318ti|fern green|California top|M-Tech]
    [URL="http://www.r3vlimited.com/board/showthread.php?t=300453"]
  • tom d
    • Nov 2008
    • 164
    what would be the reason to swap?
    it should be simple enough, but you would need to change the oilpan, ECU, and maybe a few odds and ends.
    in the long run the only advantage i can see is that you get knock sensors, so forced induction is easier.
    the M44 i believe has cast internals where the M42 has forged, so that would be the downgrade.
    • Mr.SWISS
      • Nov 2005
      • 1251
      Interested also for the e36. I have worked on both and can tell you the valve-train is def not the same as the cam locking tool doesn't fit on the M42 head without being separated but fits all 6 cyl and M44 cams as one piece. So the cams on the M42 are farther apart from each other and I think that's why the chain set up is different. I ss the only issue needing a place to put the sending unit for the temp gauge since the M44 uses a dual sender, but then again it has the wire you should be able to splice it....
      Reasoning is to have a replacement 4 cyl option other than a tired old M44. I have a swap car E30 already this car will remain a auto 4 banger as long as gas in over $2 a gallon.
      Originally posted by 325Projectz
      don't listen to the diagram... listen to mr. swiss.
      :nice:
