M42 Specific exhaust-leak issue.....
  • MikeDE
    • 1873
    On the m20 and m40, there is a ring gasket between the cat & catback sections of the exhaust.
    On the M42, it is a press/pressure fit, w/o gasket, between the cat & catback. I cannot get this PITA to stop leaking. It sounds like shit at anything above 75% throttle.
    I have already tried loosening the Trans-to-DP bracket to realign the flanges so they're straight, then tightened the spring-loaded hardware till it has just little bit of spring left. But now rather than the top leaking, it's the bottom.
    I am seriously considering just welding up conventional flanges so I can use a gasket. Anyone?? I believe there is enough movement in the muffler hangers that I don't have to worry about overstressing anything. And I have the Trans-to-DP bracket that i'm willing to bet the majority of M42 cars are missing, so I have little worry about the mani cracking.
    -03/2005 E46 330D Touring 6spd(204hp/410nM) Sapphire Black/Naturbraun Sport...300k KM & 35mpg(mixed)
  • dude8383
    • Jan 2005
    • 10387
    That's cause you are missing a gasket :D
    # 2
    http://www.realoem.com/bmw/showparts...61&hg=18&fg=10
    • rjcaptsean
      • Jul 2009
      • 51
      # 2
      Fail.
      There is no gasket there. It sounds like your connections are corroded and bent enough not to give you a good seal. Have you tried wire brushing both areas? If they are pitted you might be S.O.L. I agree that having a muffler shop weld up a connector with a gasket is probably your best option. Surely that is better than having hot exhaust gas leaking out.
      • dude8383
        • Jan 2005
        • 10387
        Originally posted by rjcaptsean
        Fail.
        whoops LOL. thought he was referring to header and mid section... read it too quickly!
        • vpilarrt
          • Jun 2006
          • 2096
          Tried the red Permatex Muffler & Tailpipe Sealer? I know it doesn't fix why its leaking, but it may keep it from leaking.
          • Dj Buttchug
            • Jun 2010
            • 7686
            or just stop being a jew and get a new exhaust...
            Turbo M42 Build Thread :Here
            Ig:ryno_pzk
            I like the tuna here.
            Originally posted by lambo
            • MikeDE
              • 1873
              Thanks for your valuable input Hitler, but the catback is new:finger:
              Read my build thread and see if I was a 'Jew', as you so bluntly put it, when I laid out the loot I did for the parts, and I bought a shitload of parts for nearly every major system on this biatch. I didn't do shit half-assed like some of the Ghetto mofo's do around r3v.
              We both have M42's so we both know how much it costs to do things right....
              • Balleristic31
                • Aug 2009
                • 4198
                Don't take asschugz seriously. He's just a naughty troll.
                -NICK
                • MikeDE
                  • 1873
                  Yeah, I can't take anybody with pink wheels seriously anyway.
                  And this exhaust issue is a good excuse to buy a welder.
