Hey guys having issues with my 91 318i, cant seem to get it to turn on.
Here is the story behind what happened when the problem started:
I went to the store a few weeks ago and the car drove fine up there and all maybe only sat in the lot for about 15min, then when i go to start it I get hesitantion then I proceed to start it at WOT and it turned on. I was driving and I slight rumble noise was coming from what I thought to be coming around the Exhaust manifold area, so kept driving it.
Once I was about 5minutes away from my house while sitting on a redlight it turned off on me and the only way to start it was by having the throttle all the way open. I kept driving and restarting the car for about 2-3 times. when I was maybe 2 minutes away the cr starts to smoke up as if it had overheated. Parked her outside the house and took a look under and there was water coming out of the radiator cap.
The next day i proceed to put some water in the radiator and once I did that I started right up, BUT when I went to drive it all went to $hits. Car died and hasnt started since then.
Things I noticed:
-The spark plugs were VERY wet(oil), therefore I replaced gaskets.
-There is alot of oil in the intake manifold and when I try to start the car it does like a back fire effect in the intake boot. When I took off the boot and tried to fire her up slight pop/flame occurs.
- I also noticed that the CPS was drained in dirt so I cleaned it but still didnt help.
- swapped batteries with a truck I have and that didnt helop either
-checked all fuses and all were good.
Need help on what to check for next, I don't know where to go next. Also is the manifold supposed to have any oil in there at all? Because there are drops in there. Thanks
Things I noticed:
