M42 budget rebuild - Upgrades to bottom end?
  • Martin C.
    • 1043
    Regarding the bottom end only, any cost-effective upgrades from stock for something that will be used as daily driver? (ie. guides? rings? etc)
    Buying parts likely this week. Opinions welcome.
    1997 328i - SOLD
    1991 325is - SOLD
    2002 325i - SOLD :(
    Currently:
    1991 318is
    2011 328i xDrive
    2017 Highlander - Toy Hauler
  • trackjunkie21
    • Jan 2010
    • 3962
    m44 block, or just take the whole rotating assembly and dump it in the m42.
    Originally posted by Wh33lhop
    VANOS: sometimes you just need to go full retard.
    • Martin C.
      • 1043
      Good point, though I do not have an m44 handy...thx
      1997 328i - SOLD
      1991 325is - SOLD
      2002 325i - SOLD :(
      Currently:
      1991 318is
      2011 328i xDrive
      • Ryann
        • 3350
        Not sure why you'd want to replace the m42 forged internals with m44 cast ones.
        I'd replace the crank thrust bearing with the 360˚ m50 piece, and if you've got the dough replacing OE cast pistons with some forged ones would be a good upgrade.
        • ///digitalme
          • Dec 2009
          • 2088
          ^^^ this!!! youre better off with m42 bits than m44
          thats what im going to do when i change the headgasket on my car..upgrade pistons....
          • twistednut
            • Nov 2007
            • 272
            Oil pressure relief valve
            what you did to this car is like getting a supermodel naked and willing to do anything you please. now here you are faced with ths once in a lifetime opportunity and then you squander it by making her fuck you in the butt with a 24" strap on. you are a sad, silly little boy.
            • KenC
              King of Kegstands
              • 14396
              The thrust bearing for the M42 was updated so it should be a 360 unit now. I'd just buy a full new set of main and rod bearings.
              Originally posted by Gruelius
              • Dj Buttchug
                • Jun 2010
                • 7667
                this.
                and also this. updated plastic relief valve. metal earlier ones tend to stick
                Turbo M42 Build Thread :Here
                Ig:ryno_pzk
                I like the tuna here.
                Originally posted by lambo
                • bwawuz02
                  • Apr 2004
                  • 653
                  I'm not sure why you think the cast parts aren't strong enough? Since rod length is the same, you have to run the M44 crank if you're buying off the shelf M44 pistons cuz M44 has longer stroke...
                  The connecting rods are forged and ~50 grams lighter and the M44 has piston oil squirters. ACTUALLY, if you get a 95 build M42 bottom end(check realoem.com for exact changeover date), it comes with these pieces from the M44. The 95 also has a revised timing setup that uses a rail near the crank sprocket instead of an idler gear, much cheaper and should swap right in to your current M42. The oil relief valve has been updated and is a cheap replacement while you're at it, just order the reg part# and you should get the updated unit.
                  Everything else has already been mentioned. If you get the M44 crank, keep the timing gear that goes on the rear counterweight or you'll have to add weight back to balance the crank, ~100 grams.
                  • Dj Buttchug
                    • Jun 2010
                    • 7667
                    ^ the m42 also has oil squirters. fwiw the cast internals will work fine for daily driving. There is really no need to upgrade. The only real improvement to be made here is the 360 thrust bearings.
                    Ig:ryno_pzk
                    • Ryann
                      • 3350
                      Why spend the money to source an m44 rotating assembly when the parts you already have are as good or better in most respects?
                      • bwawuz02
                        • Apr 2004
                        • 653
                        the parts you already have are as good or better in most respects? and if you've got the dough replacing OE cast pistons with some forged ones would be a good upgrade.
                        Maybe you should write BMW a letter and ask them why they changed their design to something not as good. Please let me know when you read about somebodies M44 bottom end coming apart on them. And btw the N55, BMW's turbo engine, uses cast pistons; but it does have direct injection, so... Do some more reading.
                        M44 = more displacement. I have the money and can piss it away any way I see fit.
                        Some people make a hobby out of taking things apart, modifying them, and putting them back together.
                        • Ryann
                          • 3350
                          I don't have to write BMW to figure out why they decided to reduce manufacturing costs by installing cast parts. Look at the numbers man. m44 is +4lb/ft of torque over the m42, and that's about it. Was it about performance and longevity or profits??
                          • bwawuz02
                            • Apr 2004
                            • 653
                            I'm not disagreeing with you on that one. As with many things, BMW over-engineered in the first iteration and cut the fat later. Just saying that fat trimming doesn't mean the parts aren't as good for their intended use.
                            The OP asked about simple upgrades for a daily-driver and you're suggesting forged pistons? really? He could get a good M44 crank and pistons for that price and see more gains.
                            • Ryann
                              • 3350
                              Fair enough. That IS the plan for mine though.:)
