stroking a m42?
  • el_4ever
    • 145
    stroking a m42?
    is there any info on stroking an e30 m42? just curious for future plans!
  • asubimmer
    • 6482
    i'm not tryin to kill your plans but WHY?!?!?
    • hamann318is
      • 3382
      The M44 had a 2.1L stroker kit. The company name escapes me right now, but there were strokers for the 4 cylinders at least. ;)
      The BMW 318 is back. With a vengeance.
      • Mystikal
        Wheel Fitment Expert
        • 9602
        Why in the hell...
        Everyone put the crack pipes down.
        • el_4ever
          • 145
          why..? don't ask. i haven't been this enthusiastic about my car since i bought my first car and i would rather stroke it to get a bit more power while still maintaing the nimble feeling that i get.
          m44? is that the swap that you had been talking about? been reading about the 320is's that were marketed in italy. 190bhp outa 2.0 would definately set this car off. i have a newly acuiered '91 318i by the way. thanks for the responses!
          • hamann318is
            • 3382
            If you want to keep the M42 and get some serious power, get the E36 M42 and the DASC.
            • AdamF 88iS
              • 2051
              Except those had S14s. Good luck on an M42.
              Adam Fogg- '88 M3
              Common sense- It's the new 'gifted'
              • rwh11385
                lance_entities
                • 18403
                hhahahahaahaha. Italian 320is...!!
                WHY WASTE TIME ON STROKING A M42??? IT IS CALLED INLINE 6 ENGINE SWAP TIME!
                • Rob
                  • 8166
                  A cheaper, easier and imho better solution would be to add a ltw flywheel, and do a MAF conversion with some dyno time.
                  BEERTECH
                  • Bavarian3
                    • 1230
                    Where in Tampa are you located? Coming to the AutoX in Brooksville this Sunday?
                    • gazellebeigem3
                      • Jun 2005
                      • 3712
                      s42? didnt that have something like 380hp? i dont remember exactly but on the website i found you could purchase all the parts.
                      • AdamF 88iS
                        • 2051
                        And it would last about 6 months before needing a rebuild.
                        The head is decent on M42s, the problem is finding a good crank and cams for it.
                        Adam Fogg- '88 M3
                        • screamingbmwe30
                          • Jan 2005
                          • 415
                          you have 2 options
                          stock crank not sure which rods and e36 m3 pistons = 2.0l around 170-180 hp +/- with good tuning cams are good for some more power not sure how much though
                          m44 crank (not as high quality as m42's but bigger stroke) +e36 m3 pistons =2.1L 180-190
                          spend 3k on the top end to get it to 8500rpm and who knows what it would make.
                          (m44 crank (not as high quality as m42's but bigger stroke) +e36 m3 pistons =2.1L 180-190 currently pieceing together right now)
                          • Digitalwave
                            is a poseur
                            • 6284
                            What is the compression with E36 M3 pistons?
                            RISING EDGE
                            • BimmerToad
                              • Sep 2004
                              • 1537
                              Static compression ratio of 10.5:1 (stock M42 = 10.1)
                              The M42 essentially has the same head (minus vanos) as the M/S50, including valve sizes/stems. E30 M42 has the same valve stem size as a NV M50 (7mm), while the E36 M42 has the same valve stem size as the M5x (6mm).
                              The main problem of building up a M42 is that to get power out of it (NA), you're going to have to get some serious cams, lifters, headwork, and standalone. Try smogging that....
                              Still though, someone needs to do it and document it. It would be a pretty involved and costly build...
                              San Diego BMW repair -> Jake @ www.littlecarshop.com Great guy :up:
