Are 1991 318is and 1991 318ic Fuel Pumps interchangeable ?
  • selturk
    • Dec 2008
    • 1197
    Can I use 1991 318is fuel pump on a 1991 318ic ?
    I see that the housing is different but what about the pumps?
  • e30jr88
    • May 2011
    • 133
    Check realoem.com there you can see if the part numbers are the same. go on that website then hit "archives" then you'll be able to see "E30". From there you can compare the part numbers.
    03' E46 M3--TCKline S/A 400F 450R -- OEM 19's-- DINAN software--330d SSK--ZHP knob
    Future mods -- headers/exhaust, 4.10 diff, 18" ARC-8's :hitler:
    91' 318i --coilovers-- skid plate--
    Future mods--new paint--E46 seats--
    • selturk
      • Dec 2008
      • 1197
      I just checked, the part numbers are different, but the price is the same.
      Looks like it won't work.
      Thanks a lot.
      • mr ilia
        • May 2011
        • 582
        you can always swap the pump within the housing.
        generic type tre or walbro will work with very minor fabrication.
        • selturk
          • Dec 2008
          • 1197
          I was going to swap the pump that I have from a 91 318is, but it doesn't work. The part numbers are different.
          These are interchangeable (same part number with a 1991 318ic vert):
          325e (1984-88, from September 1987) Coupe with M20 Engine (E30)
          325e (1985-88, from September 1987) Sedan with M20 Engine (E30)
          325i (1987-91, from September 1987) Coupe/Sedan with M20 Engine (E30)
          • bwawuz02
            • Apr 2004
            • 653
            bavauto lists the same pump for both. I can only imagine the line routing might be different. If you have the part on hand just pull it out and try it, only takes 5 min to pull a fuel pump on these cars.
            just cuz realoem doesn't show a cross-reference doesn't mean it won't work ;)
            • kalib0y
              • Dec 2004
              • 3620
              they should be interchangeable
              95 7.1L 16V E36 M3
              Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
              LIKE my Facebook Page! CLICK HERE
              • selturk
                • Dec 2008
                • 1197
                I already have it out. I tried to test fit it and the one from a 91 318is is shorter and doesn't fit good.
                • selturk
                  • Dec 2008
                  • 1197
                  Update: Ok now I have the pump connected on early model fuel pump housing, which has two tubes on the top.
                  So one of the tube on the top will be left open. Will this cause any problem?
                  • selturk
                    • Dec 2008
                    • 1197
                    Ok guys.. I just tried it and it does not work.
                    I put the old fuel pump in and it worked but it's so loud.
