Timing chain replacement time. What else while I'm at it?
  • Ewing
    • Jan 2010
    • 28
    As this title states I am about to replace the timing chain/tensioner so I figured I could do a bit more cleaning up down there while I'm at it. The engine has ~205k if that helps place it on the shit-ta-fail timeline.
    WTB: M42 air box
  • ssaylor
    • Dec 2010
    • 125
    Well, you must have a 318 with a chain. When I have the cam belt changed on the 325, I always do the water pump & thermostat.
    _________________________________
    1990 M3 Diamond Schwartz/Silver
    1989 325is Zinnoberrot/Black
    Things I've flown and driven
    • Massimo
      • Jan 2008
      • 3207
      Well if you are going to open the case replace all the guides and the chain, if the cam sprokets are worn replace them as well and if you go that far replace the crank shaft sproket just because.
      • Dj Buttchug
        • Jun 2010
        • 7677
        do a waterpump as well. drop the pan and lock tite the bolts to. thats about it
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • AndrewBird
          The Mad Scientist
          • 11898
          Basically replace anything that is worn. Should be pretty obviously once you tear into it.
          • PeabnutBubber
            • 42
            Check your cam gears (they should not be sharp) and your rails & guides etc. Check your idler gear too if you have one. Hell, take off the gear and check the casting behind it. The casting on mine just opened up and the gear fell off.
            • KenC
              King of Kegstands
              • 14396
              If your main timing guide (long one on the right) is original, replace it. The old ones are stamped steel with a plastic insert. The plastic falls away from the metal eventually.
              Originally posted by Gruelius
