correct throwout ?
  • Dj Buttchug
    • Jun 2010
    • 7686
    correct throwout ?
    okay if one is running m42 with s50 lightweight flywheel and clutch with correct pressure plate to clear the g240 transmission what throwout bearing would be used?
    The dual mass is thicker thus making the throw of the clutch arm and bearing shorter. Ive heard 323 euro throwout bearing... can anyone confirm this???
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
  • KenC
    King of Kegstands
    • 14396
    E21 323
    It's the one you're supposed to use with the M20 conversion. I'm assuming it's the same.
    Originally posted by Gruelius
    • rightcoastbias
      • 449
      Originally posted by KenC
      E21 323
      Realoem.com indicates the E21 323i M20 RHD European Clutch release bearing is as follows:
      04 CLUTCH RELEASE BEARING H=30MM 1 21511204525 $113.18
      Ref: Real OEM E21 323
      M52B28 OBD1 - G240 - S4.10
      Stuff for Sale: 24v swap parts
      • xwill112x
        • Jan 2009
        • 4236
        Euro 323i Throw out bearing is what you want. I have one if ya want it..Brand new. PM me.
        • Dj Buttchug
          • Jun 2010
          • 7686
          thanks guys ^pm sent
          Ig:ryno_pzk
