4.10 LSD medium case v.s. small, driveshaft??
  • Mtle30
    • 6
    I've got a 4.10 LSD medium case that I want to shoot into my 318, I have a driveshaft that I got off a parts car rebuilt, comes from a 325, doesn't seem to fit because of the center support not matching, any recommendations?
  • Dj Buttchug
    • Jun 2010
    • 7686
    run the stock driveshaft. the driveshaft you got may be from an auto car...
    maybe im wrong... waiting for someone else to chime in
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • bwawuz02
      • Apr 2004
      • 653
      Even it the driveshaft was from a 5spd, the G240 and G260 aren't the same length. The 240 is shorter, thus the driveshaft is longer (i think). I know for sure that the shift selector rod is a lot longer in the G240 cars ;)
      Like buttchug said, use your original driveshaft.
      • Highway1
        • Jan 2009
        • 773
        +1
        • Mtle30
          • 6
          Thanks for your help everyone, I've seen on other threads people say the ds is adjustable at the center, I'll take a better look to see that's the case
          • Teaguer
            • Sep 2004
            • 6167
            The dirveshaft will not adjust enough to make up differences between different models.
            Also the Center Support Bearing differs in diameter from early and late model bodies.
