M42 to S54 Coil on plug conversion
  • BadCab
    • 80
    Hi,
    I have been having engine missing issues with my 92 M42 when coming off idle or mashing the pedal down at low RPMs. Car has around 230k miles but i did a headgasket and changed all the timing chain and gears 2 years ago and have had 0 problems with it. Car is throwing no codes and it seems to do it more as it warms up but not all the time. I first checked the coils and wires at night and they were arcing to their iron cores and the wires had a bit of arcing too. I tried some S52 coils i had around and picked up a little throttle response but once it warmed up it started again. Tried another set of wires but it still does it. Not sure the cables i put in are good either. They were used. Swapped cam sensors and it still does it. The coils i tried were used and of unknown conditon so it brings me to this project. Stock M42 S50 S52 coils cost $65 each and up and wires are $300ish. Even if i go to a regular COP kit i am stuck with these expensive coils. All the newer engines have the pencil coils and at $30each you can't go wrong. A set of 6 Bavautos hipo coils is $250ish and is still cheaper. So yesterday i decided to do a little proof of concept experimenting.
    I have always loved the idea of COP but hated the idea of loosing my clean looking engine bay. I want my BMW cover.
    Here are the S52 coils rigged up to test.
    Here is a comparison of the later style coil next to the M42 wire end to show the height difference.
    Coil no fit, project dead......NOT!!
    Looks like the hole in my head is bigger that the cover......
    Took the valve cover off and coil has plenty of room.
    Grabbed a bad valve cover i had that has broken vent cover bolts to grind on.
    Coil boot will not fit but it shouldn't need to go this deep anyways, just checking.
    Got the dremel out with a cutting wheel and cut most of the lip off. Left a little just incase.
    Chop, chop
    Using my porting bit i proceded to open it up.
    Ground it just enough for the coil, right side one done.
    Coil fits but boot doesn't
    This is how high the cover will sit.....sort of.
    Decided to butcher a wire boot to make a way to seal the coil.
    I guess i could make it work but i am not happy with it. The coil just rattles around.
    I opened up the hole more
    Went a little too much at the 1 o'clock area but that is the purpose of doing it on this bad cover. Learn learn learn.
    Boot fits but it is too tight to get the coil in even with some organic lub.
    I opened up the hole more but this time just at the top so i keep the gasket ledge intact. A little messy but it's just a test.
    Boot fits and with a little organic lub and the coil slid in like a glove.
    Put the car back together and decided to try get a bmw cover to fit the valve cover. I made this template for the brackets. I am going to make it smaller and cleaner.
    and lower...... it probably sits too high but again, just want to see if it will work. I'll lower it when i make the brackets out of .090 aluminum sheet.
    Sits high here. I hope to lower it a bit once i know exactly how high it needs to be to clear the coils. Should look OK once the brackets are painted black. I will grind up my painted valve cover once all the parts arrive to finish this.
    So i have ordered 3 more coils (Bosch 0 221 504 464 OR BMW 12 13 1 712 219 ) and i also ordered an E46 03-05 coil harness for a M54 with the triangular plugs to run to the location of the original coil packs. I plan on cutting the sockets off of my old coils and hard wiring them to the M54 harness to go to the factory M42 coil plugs. I don't want to cut anything on my cars harness.
    Hope this helps someone out who has been wondering about the feasability of this project too.
  • Dj Buttchug
    • Jun 2010
    • 7688
    you can buy m42 coil on plug kits for like 150 bucks...
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • AndrewBird
      The Mad Scientist
      • 11898
      You kinda missed the point entirely...
      OP, great work! I have been thinking about this conversion as well as I would also like to keep the cover. Excited to see the finished product!
      • rob_e30
        • 456
        I've disassembled coils to get the connector you're looking for. I used them to build a test rig for a PnP COP Harness. They way they are manufactured makes reusing them a challenge, especially under a hood where they're subject to vibration and movement. I suspect it will be a lot more reliable to cut your harness and replace the connectors with the proper ones, including new pins (not splicing into the connectors).
        • BadCab
          • 80
          Yes Dj you can but you are buying used coils. A set of new coils to replace those will cost you alot more than that. For $125 you can buy 4 new pencil coils.
          Andrew, i hate your sig picture. It just reminds me that my poor MGB is still on the rotisserie i built 3 years ago. I swear i will paint it this year....as soon as i weld my new trunk floor in.......the last part i bought from Tony......
          I cut up my old coils and scavenged these plugs from them. The first one i cut a bit close and did not leave a ledge. I will probably get another old coil and make another. I plan on using small heat shrink on the pins and then slide a big piece of the heatshrink over the whole thing. I have some big heatshrink that is lined with hot glue and it will seal it up. If for some reason they don't work i'll splice the E46 harness in right behind the rear relay cover.
          I received my other 3 coils so i am just waiting for the E46 harness to come now. Supposed to show up saturday, if so then i will install this sunday.
          • BadCab
            • 80
            Well, had a stroke of luck and Fedex delivered my E46 harness a day early and the aluminum sheet came in too. I got home early enough to get the valve cover off and wash it so i am going to start cutting. Hopefully i will have a pencil COP powered M42 tommorow.
            • ZM Blue Devil
              • Dec 2006
              • 13836
              Good stuff, next project... S54 ITBS onto M42
              Levent
              %20levent@gutenparts.com
              Ladies:
              • Dj Buttchug
                • Jun 2010
                • 7688
                okay, so what is the benefit of running pencil coils? better spark? I cant see how a set of new coils in a COP kit is less desirable than customizing the vc ect ect...
                Ig:ryno_pzk
                • BadCab
                  • 80
                  A new set of coils for a regular COP are $260 minimum and a set of pencils are $120
                  • bmwm42
                    • 6300
                    this is true but then again comparing costs etc new cop kit cost me 150 all new coils boots etc considering they should last approx 80 to 100k and the cost of fab and all this just for a cover doesnt seem all the worthwhile imo, its a neat thing your doing there but no real advantage other than a cosmetic appearance
                    Originally posted by bmwm42
                    PNW vulture pm me for parts
                    Strategic nw e30 command
                    • BadCab
                      • 80
                      There is no performance advantage that i can think of but for those of us who have not gone the other COP route this is another option and for the same price i have 4 new bosch coils. At $120 a set i may swap the coils out biannually.
                      Wanting to get a jump on things i got most of it done this evening.
                      I went ahead and butchered up the harness.
                      ..and opened up the cover.
                      Looks like this boot may work here.
                      chop, chop.
                      I really like how this is going together. I'll seal this boot in place with some 3M window weld.
                      and the reason for going this way. Tommorow i need to wash, rewash, and rewash this cover and wire these up. Once i have that done i will know how high to make my bracket to hold the plastic cover in place.
                      • Ryann
                        • 3350
                        Agreed. Seems to me like it'd be easier and look better to incorporate the cover into Rob's COP kit.
                        Interesting idea though, props to the OP for trying something new and different.
                        • BadCab
                          • 80
                          Coils are in.
                          cover on
                          Plugged up
                          Just match up your numbers on the plugs.
                          HEATSHRINK, HEATSHRINK, HEATSHRINK. I went ahead and put number tags on the harness wires. I did the cars harness wires too. I figure i'll be glad i did at some time in the future.
                          I am only hooking up the power and signal wires on the plug. The grounds will all be tied together at the coils and an 8 gauge wire is going to the negative terminal bracket right next to the battery so there are no ground issues. Oh and more heatshrink.
                          Here is the harness done. Instead of using a heatgun on the heatshrink i filled them up with hot glue. They are nice and sealed this way, the heatshrink did contract a little and squeeze out some excess. I just held it sideways and let it drip out. I then ran a bead of hotglue around the perimeter too just for good measure.
                          All wired up.
                          The cover does not sit all that high up. I am pretty happy with it. I will make the brackets next. My feet and a$$ are cold so it is going to wait a few days. Car started right up, no CEL dash lights, no hiccups, went for a quick drive, definetly a little better throttle response compared to old wires and S52 coils but i expect probably the same as if i had replaced the wires with new ones. The old ones are pushing 230K.
                          All in all it was fun and the car seems to running real good. Hopefully i will get a little better gas mileage too. For a cleaner look the harness could go straight to the relay cover and it would eliminate all the wires but i refuse to cut this harness.
                          • Jboss12
                            • 357
                            Really appreciate the attention to detail here. Great work man!
                            • BadCab
                              • 80
                              Thanks Jboss, i said i wasn't going to do anymore but i want this done.
                              I cut the brackets out of .064 aluminum sheet i got at the hobby shop. The .090 was too thick.
                              Here they are rough.
                              A little file work
                              After a bunch of cutting, drilling, grinding, a test fit.
                              Here are the brackets, i gave them a sanding for paint.
                              3 coats flat black
                              I'll have one more update tommorow of it installed and done.
