need to clear up some clutch confusion.
  • Dj Buttchug
    • Jun 2010
    • 7686
    Ok, so I was dead set on getting the clutch setup linked below for my turbo car but after talking with a clutchnet rep he told me that the pressure plate would not bolt up to my s50 flywheel. Keep in mind I am running a g240 trans so the pressure plate has to fit inside the bell housing.
    link to clutch
    This website is for sale! clutchnet.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, clutchnet.com has it all. We hope you find what you are searching for!
    Now im confused. WTF do I use. Can someone clear this up for me? I know I can run m20 clutch with m20 fly ect ect but is there a difference in flywheels if im using a lightened s50 fly?
    Is it true that any m5x s5x clutch pressure plate will NOT fit inside a g240 trans?
    post some answers. anything helps
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
  • Dj Buttchug
    • Jun 2010
    • 7686
    wtf
    Ig:ryno_pzk
    • Ryann
      • 3350
      Skip through the bullshit and read the last post.
      • gearheadE30
        • Jun 2007
        • 3734
        My understanding is that it doesn't fit. I looked into that and also the E34 M5 flywheel setup, and that seemed to be the consensus. Apparently the e36 transmissions have a little more room in the bellhousing casting than the G240. The M20 setup is physically smaller than the m/s50/2 stuff. For whatever it's worth, I'm running an M20 clutch and flywheel with the starter mod, and the FW has been lightened to 13 lbs and it's been great for me, though you are running a lot more power.
        IMPORTANT EDIT: apparently I'm wrong. I never could find anyone who actually tried it.
        Project M42 Turbo
        • Dj Buttchug
          • Jun 2010
          • 7686
          Originally posted by Ryann
          http://www.r3vlimited.com/board/showthread.php?t=166493
          nice. i guess im g2g with a m50 clutch set up then.
          Ig:ryno_pzk
          • Ryann
            • 3350
            ^Do everyone else a favor and document it better!
            • Dj Buttchug
              • Jun 2010
              • 7686
              hell yea. ordered one so I will update on everything
              Ig:ryno_pzk
              • bwawuz02
                • Apr 2004
                • 653
                if the M/S50 stuff doesn't work, you can always try the sachs HD pressure plate that all the S14 guys use w/an M20 flywheel.
