Gas in Oil???
  • S13_E30
    • 309
    Gas in Oil???
    I want to get your guys opinion on what might be causing there to be gas in my oil. From what I've read and previous experience of this happening to my 240. It can be a couple reasons, Bad o-rings , piston rings, the car running to rich (it shouldn't be though???) and I've heard something about maybe a bad fuel pump??? If you guys could pitch and help me buy giving your opinions I'd appreciate it.
  • Dj Buttchug
    • Jun 2010
    • 7673
    not sure what you mean by o ring...
    1. bad rings. un burned fuel is seeping past the rings ending up in the oil
    2. running rich causing fuel to wash the cylinder walls which ruins rings eventually
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • cabriodster87
      • Jan 2011
      • 1042
      Injector leakdown?
      Reich und Roll!
      • lolcantturn
        • 4588
        2 Stroke engine?
        Originally posted by TSI
        OEM+
        • JTDay
          • Dec 2009
          • 521
          if injectors are leaking badly you can hear the tss, tss, tss of unburn furl hitting the top of the hot pistons when you turn the car off.
          Past: 1987 325iS, Bilsteins - HR Sports
          Present: 1999 M3, Koni Yellows - HR Sports - GC Camber Plates - UUC Swaybars - UUC SSK - AFE Intake - Stromung Catback
          2009 Mazdaspeed3, Short Ram Intake - Turbo Inlet Pipe - 2nd cat Delete - Catback - Fuel Pump Internals - Cobb Accessport - Stratified E30 tune - 294/342 - SPC Camber Arms - CPE Rear Motor Mount
