M42 randomly dies
  • Dj Buttchug
    • Jun 2010
    • 7688
    M42 randomly dies
    I think i have it diagnosed but I just thought Id throw this up to keep my options open.
    the daily shitbox randomly dies. Once earlier this week at idle in a parking lot it just decides to shut off. Tonight driving about 50mph I get a huge hiccup. Spark being cut for at least two seconds, it felt like aleast. Then back to normal. So I let the gas off coast for a bit then pop into neutral and bam... dies right there while coasting.
    Cam sensor reads 1540ish OHMS
    Crank sensor reads 604 OHMS
    both cam and crank sensor wires are chewed up. the wire at the base of the crank sensor is pretty bad.
    I think my crank sensor is randomly shitting out on me. After the car dies it itll start right back up. other times i get a hard start
    Fuel pump is TRE and is brand new
    NO CEL
    lemme get some input
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
  • bmwm42
    • 6300
    sensors big time yo time to replace that shit bro lol
    Originally posted by bmwm42
    PNW vulture pm me for parts
    Strategic nw e30 command
    • immajackuup
      • Dec 2010
      • 1132
      NO CEL
      fix that first before anything else,did you check fuel pressure?
      • Dj Buttchug
        • Jun 2010
        • 7688
        robbing parts off my flawless super expensive turbo engine...
        FUCK.
        MY.
        LIFE.
        Ig:ryno_pzk
        • immajackuup
          • Dec 2010
          • 1132
          FUCK.
          MY.
          LIFE.
          junkyard?
          • bmwm42
            • 6300
            my simple guess is the wires get hot or whatever grim you have around those exposed wires is causing a false reading causing the dme to think wtf is going on and cause the miss
            • trackjunkie21
              • Jan 2010
              • 3962
              Had the same problem on my m42 car and randomly have it on my m50 car now, still cannot pinpoint the issue.
              Originally posted by Wh33lhop
              VANOS: sometimes you just need to go full retard.
              • Dj Buttchug
                • Jun 2010
                • 7688
                Originally posted by immajackuup
                junkyard?
                haha
                I think this is right. I just swapped both cam and crank sensors out for known working ones... didnt stall out and I just got back from 20 mile freeway test.
                :( the e30 gods are mad cause you no turbo. see what happens. karma lol
                Ig:ryno_pzk
                • Dj Buttchug
                  • Jun 2010
                  • 7688
                  This POS shit box has to carry me and an assortment of e30 parts to SD in less than two days. from driveway to driveway its a total of 521 miles. The best part: I am out of tows with AAA. Im a premier member and am only allowed 5 pr year. Ive used all five this fiscal year towing my Volvo that I recently sold to a kid down the street.
                  Ig:ryno_pzk
                  • trackjunkie21
                    • Jan 2010
                    • 3962
                    I'm wondering if there is anything in the body harness that could be causing this.
                    • Dj Buttchug
                      • Jun 2010
                      • 7688
                      Considering thats about the only thing that wasnt changed when you did the swap related to engine wiring ect. really good idea actually
                      Ig:ryno_pzk
