M42 Overheating After Timing Chain
  • Tisoc
    • Jul 2011
    • 249
    I finished rebuilding the timing case on my m42 & the engine is running better than ever. Unfortunately, the car is giving me overheating problems now. I tested both the old & new thermostats in a pot of hot water & they both opened up at the specified temperature, so I ruled that out as the issue. I also tried bleeding the system, to no avail. I'm thinking it could be the water pump (which I did not replace), but I am not certain. It's strange because I was not having any overheating issues prior to the timing chain. I just want to drive the damn thing again! Anyway, if any of you guys could help me with my cooling system woes, it'd be much appreciated.
    Thanks.
  • KenC
    King of Kegstands
    • 14396
    There are a ton of threads on bleeding at m42club.com
    Originally posted by Gruelius
    • Dj Buttchug
      • Jun 2010
      • 7677
      its not the water pump. you have a huge bubble in the system
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • Gerta
        • Sep 2009
        • 2119
        Look in this forum for Ryann's thread on bleeding. I followed that and it removed a similar issue.
        Parts Collector and Former Houndstooth interior junkie.
        • Tisoc
          • Jul 2011
          • 249
          Thanks for the replies guys. Vivek, your method worked flawlessly, thanks mang.
