Profile Gasket Leak?
  • Threehz
    • 1480
    Well I've read about the elusive profile gasket and how it is prone to failure. I'm wondering if mine may be going out (although I'm sure it's been replaced at some point with 223k miles right now)
    This is not my engine, but that red circled area is where water collects, I can dry it, but it will collect there again, so I'm guessing I have a small leak.
    Any ideas?
    My engine oil has never shown any symptoms of coolant leaking into it (thank god).
    Different strokes for different folks.
  • twistednut
    • Nov 2007
    • 272
    Probably just a thermostat housing leak. The profile gasket is located below the housing.
    what you did to this car is like getting a supermodel naked and willing to do anything you please. now here you are faced with ths once in a lifetime opportunity and then you squander it by making her fuck you in the butt with a 24" strap on. you are a sad, silly little boy.
    • bmwman91
      • Oct 2004
      • 3133
      The profile gasket is way under there, so it is not that.
      My bet would be on the thermostat housing being cracked up around where the upper-right bolt is in the picture. I had that happen once and it was causing coolant to puddle up where you circled.
      Transaction Feedback: LINK
      • Threehz
        • 1480
        Sweet! That is reassuring, not too hard of a job?
        • bmwman91
          • Oct 2004
          • 3133
          It isn't too bad. See if you can find a crack first though. It could be the gasket too.
          You have to drain & bleed the coolant system, and replace the housing gasket if you remove it.
          • Threehz
            • 1480
            Well I have a new water pump, thermostat, and I think I got the gasket as well, just haven't had time to do the job yet. So either way it will get attended to, I'll give it a thorough look over.
            • KenC
              King of Kegstands
              • 14396
              Use RTV and follow the instructions. Those aluminum housings will warp a little over time from heat cycling.
              Originally posted by Gruelius
