Mess under the intake? Read this!
  • Vivek
    attention whore/retard/bitch
    • 6167
    #31
    I just got the smallest size I saw at kragen, I think it was like $0.49 for the foot.
    1992 Mauritiusblau Vert
    2011 Alpinweiss 335is coupe
    2002 540i/6 Black/Black
    2003 GSX-R 750 (RIP)
    • duleymane///iS
      • Jun 2012
      • 153
      #32
      its a little harder to find it here in germany for some reason all the auto parts stores do not carry vac lines, just heater hose, no fuel lines either ive tried like 5 or 6 different ones, pelican and turner are life savers!
      • duleymane///iS
        • Jun 2012
        • 153
        #33
        so update just did it yesterday like stated earlier and its about 100 degrees today and im puking coolant from under the manifold, 1. i put too much coolant in yesterday could that be why its puking out, and 2. i am fairly certain i tightened the crap out of all the coolant lines.. im at a loss its so effing hot and i dont wanna pull the intake again, i drove about 50 miles since the i did the work.. car runs fine just leaking coolant all over the block
        • jrobie79
          • Mar 2006
          • 2526
          #34
          gotta be that plastic junction pipe...did you change it during this process?
          1991 318i ---- 308K - retired
          • duleymane///iS
            • Jun 2012
            • 153
            #35
            it was the hose i used from the pipe to the block it was too old and just ripped i plan on replacing it today after work i got a hose from some german hydro shop its good up 58 bar and 110 degrees C. so hopefully it works they were nice and gave it to me for free
            • Thizzelle
              • 4422
              #36
              any benefit to this?
              "I wanna see da boat movie"
              "I got a tree on my house"
              • oldmann
                • 265
                #37
                It is to eliminate all the extra failure points, and possible leaks in nearly inacessible locations.
                • Vivek
                  • 6167
                  #38
                  If you take it apart to fix the vacuum leaks, you'll soon realize that it's all but impossible to put it back together the way that they did it originally.
                  • ///M42 sport
                    • 3952
                    #39
                    ^^ dude your comment is a little rediculous. NO its not next to impossible to replace everything back to stock. I did it and I dont consider myself a expert mechanic. only benefit I see is ease of maintenance and possibly cheaper to not have to replace all hoses. Otherwise theres no difference
                    • Chrisv006
                      • 375
                      #40
                      Can anyone post the coolant / vacuum hose sizes needed? Would be super helpful. Ordering the rest of the parts tonight.
                      • brent5631
                        • Jun 2012
                        • 421
                        #41
                        3 ft of 19/32 vacumn hose
                        1ft 5/8 heater hose (to make the bypass form the plastic junction to head)
                        3ft 5/16 fuel injection hose
                        Thats what I used. You'll need more heater hose if eplacing lines to the heater core.
                        • Chrisv006
                          • 375
                          #42
                          Your the man, saved me a trip :-)
                          • unevolved
                            • Nov 2011
                            • 714
                            #43
                            Just did this last night. Used some parts from a Miata PCV system to make the bypass from the plastic junction to the head, 1/2" heater hose from the valve cover to the throttle body, and 5/8" heater hose from the ICV to the intake.
                            This should be stickied.
                            1991 318i SOLD
                            2003 325i SOLD
                            Racecars and stuff.
                            • Ryann
                              • 3350
                              #44
                              I agree with this 100%. While it may be cheaper to driveway engineer a simplification of everything with shit you found at Home Depot, the stock setup is easy to replace and really not that messy once you've revamped it and know what you're looking at.
                              Also, the notion that stuff under the intake is 'inaccessible' on an m42 seems odd to me. It's probably the easiest intake manifold I've ever removed.
                              • Vivek
                                • 6167
                                #45
                                Then why do most people, even people like Simon S, use this method? It's not because they're too lazy/unskilled, I can tell you that much.
