Mess under the intake? Read this!
  • Vivek
    attention whore/retard/bitch
    • 6167
    This picture is the single best thing you can possibly have during this job. It's from M42 club so I can't take credit for it, but there's not too much useful info on r3v about this issue. Here you go:
    Print it out, write on it, highlight it, love it. You'll be so glad you have it.
    I'll also share a few tips of my own:
    Look at that pic first, before you order anything. I didn't end up using half the stuff I bought because I didn't see that diagram in time.
    Put vaseline on the fuel injector o-rings to make them slide in. I did the same thing on the fuel hoses, but be careful that the vaseline won't get into your gas.
    When I took it apart, I was like ohhh god there is no way I can ever put this back together. Taking it apart is harder than putting it back together, don't worry.
    Here's a couple pics of my own:
    This is the only coolant hose you need to modify. I didn't get the correct diameter (everyone said 5/8, which was too big for me), so I just used the one that was on there and twisted it a bit. It should be fine.
    And there you have it. It's overall a fairly easy job...and this is the biggest job i've ever done on a car at this time.
    1992 Mauritiusblau Vert
    2011 Alpinweiss 335is coupe
    2002 540i/6 Black/Black
    2003 GSX-R 750 (RIP)
  • e30jake
    • Feb 2012
    • 855
    Nice, wish I would have seen that diagram earlier. Also apparently you don't need to have that hose going straight from the pipe to the head you can just plug them. I put it on anyway (19/32 I think) to be safe but it is one less hose to go bad...
    What it feels like owning an e30:
    88 325 S50 swap in progress
    90 325ix
    • Vivek
      • 6167
      Oh yes, I forgot to add that. You can plug both ends, but for me just sticking the hose on was easier.
      • Dj Buttchug
        • Jun 2010
        • 7654
        everything in blue except for main coolant pipe connected to block and heater core stuff as well as almost everything in red can be completely removed and thrown away.
        best picture ive seen
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • jrobie79
          • Mar 2006
          • 2525
          those fuel line hose clamps look a little big?
          1991 318i ---- 308K - retired
          • M3Philipp
            • Jul 2011
            • 278
            The ones he choosed are fine considering size.
            • roguetoaster
              Biggus Tippus
              • 7818
              I am amazed someone found my pic in the mess that is the mess thread! Glad you found it to be helpful! I only wish I has not used blue/purple, made it hard to differentiate, but it was only for personal use at the time. On another note M42club is rather dead ATM, post up there too!
              • Massimo
                • Jan 2008
                • 3207
                Like me if you ever take the head off get the mechine shop the weld it up. Then just throw a bolt with some silicon on the connection to the plastic pipe. Will never leak ever again.
                • M3Philipp
                  • Jul 2011
                  • 278
                  Is it common on the M42, that the big plastic water pipe on the engineblock (which is marked blue in the graphic) starts leaking water?
                  • roguetoaster
                    Biggus Tippus
                    • 7818
                    Yes, it generally starts at the plug in to the block, but is also known to crack on the outlet to the cylinder head. Ideally if someone would make an aftermarket part to fix that and have it work with the mess deletion it would be awesome, sadly it will never happen.
                    • Massimo
                      • Jan 2008
                      • 3207
                      Maybe ill have to look into this.
                      • Vivek
                        • 6167
                        Nope. I know it seems like they were near their tightening limit, but it was impossible to get them any tighter.
                        Thanks man! This pic is an absolute life saver. And I got it from m42 club on the 14th page (i think) of the MUtI sticky.
                        Here's a basically finished pic of my m42 if anyone's interested:
                        • roguetoaster
                          Biggus Tippus
                          • 7818
                          Looks purdy! Two things, maybe cut the TB studs back some, I did, made my life easier considering how often I have the manifold off (and how infrequently I can find my 10mm deep socket!), and that hose off the the VC looks stock & I like that. How did you fit it to the intake boot anyway, just a plastic barbed connector?
                          • Bmr
                            • Jul 2009
                            • 322
                            Thanks for this diagram. Worked on the 318 tonight and removed all that crap. Took about 4 hours. While I was in there I added some 19lb mustang injectors. Cat runs great and it looks much better. I didn't even need new hose. All the old stuff was able to work easily with the new setup. +1
                            • roguetoaster
                              Biggus Tippus
                              • 7818
                              I hope those were injectors that clip into place, some people have had leaks over time with non clip in ones.
