What Could Have Caused an Alternator to go bad so soon?
  • Learning
    • Feb 2011
    • 70
    Hi,
    I had a brand new alternator and battery replaced about 1.5 years ago, but the alternator is not charging now according to a test done by a AAA personal. He jump started my car and as soon as he disconnected the battery charger from my car's battery, my car started to shake and then the engine stopped running. He said the alternator wasn't charging.
    What factors could have caused the alternator to go bad so soon?
    I'm told an alternator should last as long as 5 years or even more.
    Please shed a light.
    Thank you.
  • FLG
    • Sep 2011
    • 3165
    What brand alternator? New? Rebuilt?
    Sent from my Galaxy Nexus using Tapatalk 2
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • Learning
      • Feb 2011
      • 70
      I believe the mechanic told me he installed a new rebuilt alternator 1.5 years ago as a totally brand new alternator is much more expensive and uncommon.
      • FLG
        • Sep 2011
        • 3165
        Could just been a cheaply rebuilt unit. Bosch? Or other brand?
        Some rebuilt units are done good, others are done on the cheap. There's nothing in particular that would cause a alt to go bad. Assuming its not being over worked due to a bad battery or you have some kind of killer aftermarket audio stuff...its probably just a cheap rebuild or a fluke.
        Bring it to the mechanic...he might be able to work something out with the parts warehouse who he deals with and get you another one due to this on failing so quickly. Generally they don't warentee electrical parts but its possible he can get a discount or replacement.
        • Learning
          • Feb 2011
          • 70
          It's a Bosch.
          I thought Bosch was a good brand.
          • idanity
            • Jun 2006
            • 775
            i got a bosche from a local auto parts store for about 100, and the 1st one went bad in a week..replaced for free, now (5 months later) it is barely charging, just at 13.v and not normal 14.4v so, i think mine is going out (again) too...
            maybe there was a bad batch of them ?
            maybe they started using crap parts ?
            all i know is there is a lifetime warranty on bosche parts from my local auto parts store, and your mechanic should also have a similar (at least a year or 2) warranty.
            if not, maybe its time to replace it yourself with one that does have a lifetime warranty.
            its odd, that my 88 yota trucks altenator is original, and has over 350k miles (odometer actually stopped at 350k) and it still works...its been whining for years, but still charges...maybe i should figure a way to use a toyota alt ...
            3 pedal club
            200,k+ club
            cabrio club
            port-matched- polished- purring www.BMWpark.org
            </div>
            linux since 1999
            • reelizmpro
              • 9559
              hmmm check the voltage regulator? In 20 years, I've never had to change a bad alternator in an E30 and I've had a few. Belts, brackets, ground cables and voltage regulator brushes go bad but never the alternator itself. Or maybe I've been lucky?
              88 M3 - LACHSSILBER
              89 M3 - ALPINEWEISS II
              • MF DOOM
                • Apr 2012
                • 944
                Add a ground from alt. to chassis
                • Learning
                  • Feb 2011
                  • 70
                  I remember well my mechanic connected a thick ground wire from alternator to engine block.
                  • Exodus_2pt0
                    • 5943
                    That won't really do much... Since the alternator is bolted to a bracket, bolted to the block.
                    You need to ground the engine out, I replaced the oil pan to body ground, and added another from my intake manifold to strut tower. It's worth a shot.
                    No E30 Club
                    • MF DOOM
                      • Apr 2012
                      • 944
                      Add one directly from your alt to the chassis. I was running two grounds from engine block to chassis and my alt wasnt charging. added a ground on the alt. and problem was solved. The ground wire cost me 12 bucks at napa
                      • Balleristic31
                        • Aug 2009
                        • 4198
                        Make sure your belt is aligned correctly and not wiping out the alternator bearings. Mine did that and I toasted a new Bosch in about a year.
                        -NICK
