Valeo single mass conversion clutch kit
  • bonham123
    • 35
    Anybody have any experience with the single mass conversion clutch kit that they make? Thinking it may be easier then sourcing all the parts for an m20 conversion.
  • bonham123
    • 35
    Well I went ahead and purchased it from amazon for 447.00. The bad boy came in today.
    I want to turn the flywheel an take a couple pounds off. Looks like there is some meat I can turn off the back. But want to double check with Solidworks too make sure it will be structurally ok. Hopefully I will get time this weekend to borrow a friends lathe and turn that puppie down.
    • Massimo
      • Jan 2008
      • 3207
      Hmm this looks good how much dose the flywheel weight? qurious if it is lighter then the stock model.
      • Dj Buttchug
        • Jun 2010
        • 7688
        interested in weight as well. I guess for 5 bills thats not a bad deal.
        op report back with install and drive feel ect
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • bonham123
          • 35
          Just checked the weight. The flywheel by itself is 22 lb. and the pressure plate and disk are 13lb. Coming to a total of 35 lb.
          From what I'm reading the oe dual mass is 38lb. total. But I think I will weigh what comes out of the the car just to fact check.
          I should hopefully get this in sometime next week. Depending on if I decide to shave some weight off or not.
          And if you guys are interested just google the valeo part number 52161203. Amazon had it for the cheapest.
          • Massimo
            • Jan 2008
            • 3207
            So it is the same weight as the oe single mass. let us know if you shave it and how much it weighs after
            • brent5631
              • Jun 2012
              • 421
              Does this require a starter change like the m20 swap? Or a new throw out bearing?
