i tried searching and read a few things but nothing that helped.
so i am not getting power at the fuel pump for some reason.
the pump is working. i hooked it up to a power source and it pumped well but when i crank over the engine or turn the key it donest pump. i was thinking it was a ground wire or something.
it was working literally a week ago but now nothing. i did change the ALT and didnt hook up that ground wire from the engine to the ALT. idk if that would really be a problem since the ALT is touching the engine anyways.
im going to try to power the fuel pump with my power source and try to start my car. because the damn thing isnt starting!!!
LMK what could cause the fuel pump not to start. i was thinking crank shaft sensor, but i thought that controls the Injectors.
idk. maybe a relay went out.
