fuel pump noise?
  • Chriskbmx
    • Apr 2012
    • 972
    fuel pump noise?
    the fuel pump on my car is very loud and i was wondering if this is normal. i just put the motor in the car and this is my first time driving an m42 car.
  • AndrewBird
    The Mad Scientist
    • 11898
    You shouldn't be able to hear it over the engine I would say. A loud pump is indication that it is going out.
    • Quadrajet
      • Jul 2008
      • 1278
      Or that the fuel filter needs to be changed.
      • Chriskbmx
        • Apr 2012
        • 972
        im changing the fuel filter tonight. hopefully that fixes it. does anyone know which relay is the fuel pump relay?
        • LegionHelium
          • 71
          Fuse 11 is the fuel pump I do believe
            Agreed! A loud pump is one that is having to work too hard (clogged filter or obstructed fuel lines) or a dying pump. But do check the tank for rust as a rusty tank will kill a new pump pretty quickly.
            • Chriskbmx
              • Apr 2012
              • 972
              ughh i sure hope its not that. its my daily lol. whats the easiet way to check?
              • Dj Buttchug
                • Jun 2010
                • 7643
                when it does go out get a TRE pump. there cheap and they are fkin awesome
                Turbo M42 Build Thread :Here
                Ig:ryno_pzk
                I like the tuna here.
                Originally posted by lambo
                • twistednut
                  • Nov 2007
                  • 272
                  Chug, how much modification was necessary to make the TRE fit and what did you do to terminate the wires to the factory plug?
                  what you did to this car is like getting a supermodel naked and willing to do anything you please. now here you are faced with ths once in a lifetime opportunity and then you squander it by making her fuck you in the butt with a 24" strap on. you are a sad, silly little boy.
                  • Dj Buttchug
                    • Jun 2010
                    • 7643
                    the TRE unit installs just like the OEM bosch style does. it comes with a harness adapter and all you have to do is splice in two wires, a hot and a ground. its cake, and the pump comes with connectors you need
                    Ig:ryno_pzk
                    • bmwm42
                      • 6300
                      yup its cake to do im running one in my alpine car
                      Originally posted by bmwm42
                      PNW vulture pm me for parts
                      Strategic nw e30 command
                      • Chriskbmx
                        • Apr 2012
                        • 972
                        yeah i think thats what im going to do. i like the idea of having higher flow rates.
