hey new to r3v
  • E30kidzgmr
    • Oct 2012
    • 3
    hey new to r3v
    I got a 91 318 i pulles the motor to clean the block check vac lines motor Mounts and now got everything back in when i turn the key i don't hear my fuel pump turn on so i turn of my key and turn my key back on then off like 6 times then turn it on and I'll hear my fuel pump turn on then i crank and it will start but run like shit bogs when i give it some gas I'm really trying to get it running to use as my daily cuz i got a 08 bagged jetta im trying to put in the garage and wire tuck the bay for big socal gtg please help out
  • Dj Buttchug
    • Jun 2010
    • 7686
    1. you forgot to hook something back up i.e. vacuum lines
    2. check all your grounds
    3. jettas are gay
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • roguetoaster
      Biggus Tippus
      • 7830
      Really, if you want actual help you need to phrase your question as a question, not as some sort of bro speak run on.
      My guess is that you did something wrong and you should totally S50 swap it. Helpful, right?
      By the way #1 above is probably correct.
      • E30kidzgmr
        • Oct 2012
        • 3
        Ya sorry ours just been a long day with this car I did do an SCT too swamped but I blew the bottom and I put the M 42 back in just so I could drive it but the ipulled my m42 out to clean it up i just rechecked everything right now i just noticed my fuel filter is smashed.
        So i replaced the fuel pump relay but my FP still not turning on when i turn my key on what else could be causing it to not turn on?
        • E30kidzgmr
          • Oct 2012
          • 3
          3. jettas are gay
          I would love to hear how jettas are gay hahahaha
