318is Fuel Mileage Problem
  • NickMav
    • Aug 2012
    • 75
    Hello, I have a 91 318is M42 with 146,500 miles a supersprint catback exhaust and a 3.73 lsd. I averaged my mpg to around 16ish mpg. This should be way higher shouldnt it? Im going around 260 miles on a 16 gallon tank. I dont even really beat on it, I daily it to school and work. Im always shifting under 3k too and occasionally ill get on it to pass someone sometimes. Its not like im bounching off rev limiter and dumping the clutch either ill just take it up to around 6k no more. My car even smells rich sometimes so I know its getting to much fuel. I recently replaced the fuel filter, thermostat and coolant flush. Air filter is clean. Didnt have a chance to pull the plugs but was going to do that soon and most likely change 02s. Any ideas that I could be missing on why my mpg is so poor? Thanks guys
  • Dj Buttchug
    • Jun 2010
    • 7688
    change o2 and check for vac leaks. I can get well over 400 miles to the tank on the freeway, also the tank is 12.6 gallons pretty sure
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • e30Chris
      • Nov 2012
      • 68
      Get the plugs changed (avoid Bosch Platinum at all costs, NGK worked great for me) and change O2 sensor. Is it getting up to operating temp with the new thermostat? How's it idle and accelerate? Could be a vac leak too. And did you swap in a 16 gallon tank? The stock tank is 14.5.
      • gearheadE30
        • Jun 2007
        • 3734
        Stock tank on 318is's is 12.6 gallons. 14.5 was for some of the 6-cylinder cars. I typically get between 28 and 32 mpg.
        Project M42 Turbo
        • NickMav
          • Aug 2012
          • 75
          Mitchell1 Says its 16.4 gallons or 62.1 liters. I was going to use the ngk spark plugs anyway. With new thermostat it is running right at the halfway mark before it would never even go past the quarter mark so i fixed that. Im going to change the 02 when I do the spark plugs and see what happens. Thier may be a vac leak to because under the intake where that mess is the p.o tapped up some hoses.
          • NickMav
            • Aug 2012
            • 75
            I just checked realoem and put in my vin and it said i have a 55 liter tank or a 14.5 gallon tank. Im confused on what i have no im pretty sure the p.o didnt change the tank but my fuel gauge does read as f is full and 1/2 would be empty. I think its the sending unit that is causing that. I probably have the 14.5 gallon tank but thats still only like 17mpg
            • eur04lif3
              • Jan 2009
              • 756
              Ya, that's most likely your issue.
              I get between 28-31, depending on whether i just cruise or sprint through corners. :up:
              Worst i ever got was 27.8 and that was mostly city and old sparks and O2 sensor.
              • eur04lif3
                • Jan 2009
                • 756
                Wait, how are you getting your MPGs?
                You should be doing the old-school way, every fill up check mileage and gallons filled up.
                • NickMav
                  • Aug 2012
                  • 75
                  Thats what I did, then just divided how many miles by 14.5 gallons its around 250ish thats when my light comes on. Ill guess ill be doing the mess under the intake mod. Does anyone know how much this will cost? Can i just but hose from parts store i havrnt really checked to see if theres any weird hoses but i did go under there when i got home and moved the one hose that goes to the airbox and my engine would idle diff. at idle its around 800 but sounds like theres misfires randomly not all the time and acceleration is good but atound corners sometimes the car wants to cut off. Thought it could be sending unit since gauage is messed up too but maybe the engine is moving and that vac hose is loosining up?
                  • Vivek
                    attention whore/retard/bitch
                    • 6167
                    My tank is I believe 16 gallons because I've filled 14.5 many times soon after the light comes on and almost 15 once. Maybe it's different on a vert?
                    There's an excellent thread on this here (Simon's) and another okay one (mine). It doesn't cost much at all, off the top of my head I think everything important can be done with parts locally. I opted to not replace some of the coolant things that Simon suggested (like the plastic hose) because I don't mind too much if I have to take it apart and fix it.
                    1992 Mauritiusblau Vert
                    2011 Alpinweiss 335is coupe
                    2002 540i/6 Black/Black
                    2003 GSX-R 750 (RIP)
                    • irish44j
                      • 2763
                      Early cars had smaller tanks too. My '85 318 is the 12.6 gallon tank, IIRC.
                      Stage rally/rallycross e30 build/competition journal
                      Track/street e21 build
                      visit Condor Speed Shop
                      visit Motorsport Hardware
                      [FONT="Franklin Gothic Medium"] 1985 318i/M50 Rally Car - 1988 Porsche 924S - 2005 Sequoia tow pig - 2018 GTI
                      • Dj Buttchug
                        • Jun 2010
                        • 7688
                        interesting because I cant ever get more than 12 gallons in my car. My 318i was a late model 1991
                        Ig:ryno_pzk
                        • gearheadE30
                          • Jun 2007
                          • 3734
                          For whatever it's worth, mine is a march of 1990 car, so pretty early, and it's got the 12.6 gallon tank...the smallest a 6-cyl car ever got was the 14.5, but I'm not sure which got the biggest tank.
                          Project M42 Turbo
                          • TimKninja
                            • 2131
                            My 318is had a 11 gallon tank.
                            My 325is has a 14 gallon tank.
                            1985 325e M50TU(Sold)
                            1991 318is Slicktop (Sold)
                            1990 325is Brilliantrot S50/5 Lug Swapped.
                            1992 525i Manual shitbox Winter Beater
                              If you check the IPB (realoem.com or similar) I believe you will find that all US 318 cars had a 55L tank. All 325 cars had the same tank up to 8/87, when the tank was changed to a 63L type. The easy way to tell difference is that the 55L tank has a single opening on the right side for the pump/sensor and the 63L tank has an opening on both sides. I believe that some non-US 318 cars had tank smaller than 55L.
                              The only valid method of obtaining fuel mileage is to record the mileage (or zero the trip meter), fill the tank, drive the car until it needs fuel, note the amount of fuel needed to fill the tank, and divide the that by the miles driven. You will get better numbers by recording starting mileage with a full tank, recording fuel added for each of several refills, compute the total fuel usage and divide by total mileage.
