m42 replacement engine.. questions on what to replace
  • smashed s4
    • 105
    hey guys so i picked up a very clean 91 alpine a few weeks back. m42 was seized. interior and exterior are near flawless..
    anyway, i just picked up a running m42 with 170k miles. gonna start prepping the replacement swap. what do you guys recommend i replace to keep this m42 running strong? valve cover gasket, spark plugs, any sensors? anything that is common to fail on these motors? sorry i dont know much about these guys yet.
    ive heard upper and lower oil pan bolts. i know the upper is hard to get to when its in the car, will definitely change that too..
    oil pump?
    any help is appreciated! ill just start making a list of things to look at/replace
    thanks!
  • ///digitalme
    • Dec 2009
    • 2088
    define strong??
    gaskets, make sure the sprockets are in good shape...if you want to go further, complete timing overhaul(which by the way is expensive)
    • ///digitalme
      • Dec 2009
      • 2088
      mess under the intake is a must....
      • smashed s4
        • 105
        can you expand on this?
        • getouth
          • Jan 2010
          • 3343
          ^^^all the vacum connections under the intake manifold there is a pretty extensive thread here dedicated to it. Timing tensioner and a full cooling system overhaul are some major things to consider.
          FEEDBACK:
          http://www.r3vlimited.com/board/showthread.php?t=316212
          BMWCCA #398608
          IG @yagayo38
          "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
          • irish44j
            • 2763
            replace the front and rear crank seals. They're cheap and easy to replace while the engine is out of the car, but a PITA to replace if they start leaking with the engine in the car.
            Also worth pulling the oil pan to make sure none of the upper pan bolts have fallen out, as seems to happen to everyone. if not, take them out, clean them up, and loctite (blue) them and then put back in torque to spec.
            Stage rally/rallycross e30 build/competition journal
            Track/street e21 build
            visit Condor Speed Shop
            visit Motorsport Hardware
            [FONT="Franklin Gothic Medium"] 1985 318i/M50 Rally Car - 1988 Porsche 924S - 2005 Sequoia tow pig - 2018 GTI
            • smashed s4
              • 105
              parts ordered! gonna fix the cooling mess under the intake along with a bunch of seals and gaskets and h20 pump!
              • bmwm42
                • 6300
                id suggest replacing the timing chain tensioner unless you have documenation as to when last replaced and i would also remove the vc to inspect the cam gears and also removing the lower oil pan to inspect bolts
                Originally posted by bmwm42
                PNW vulture pm me for parts
                Strategic nw e30 command
                • jrobie79
                  • Mar 2006
                  • 2521
                  check your spark plug holes...if there's oil in there I'd do the VC gasket and plug gaskets
                  1991 318i ---- 308K - retired
                  • smashed s4
                    • 105
                    hmmm.. timing tensioner too? how hard will that be to do while its in the car?
                    • Ryann
                      • 3350
                      ^Search this sub forum, it's covered extensively here. If you want to dig deeper replacing the crank thrust bearing with the updated m50 360 degree version would be a good idea. I'd also definitely change your thermostat and pull the timing covers so you can inspect the chain guides.
                      • series88
                        • Nov 2011
                        • 1231
                        learn from me, I didnt get to change a bunch of seals and she leaks like hell...Were you the one that picked up Jericho's m42?
                        • smashed s4
                          • 105
                          im replacing a crap ton of seals and gaskets! but yes i picked that one up!
                          • series88
                            • Nov 2011
                            • 1231
                            lol forsure. just put 2 and 2 tohether....The SJ car sold, his engine sold and that post on e30 pcs
                            • AndrewBird
                              The Mad Scientist
                              • 11897
                              Check for crank endplay. The 180º main bearing can wear on the crank causing a lot of excess play. You can replace it with a full 360º bearing. Well worth it IMO since you will have the pan off. Prevents damage to the crank (which will be very expensive to fix later), unless the crank is already worn.
