m42 replacement engine.. questions on what to replace
  • jrobie79
    • Mar 2006
    • 2526
    how hard is it to change the thrust bearing? and how can I tell if the crank is worn too far?
    1991 318i ---- 308K - retired
    • AndrewBird
      The Mad Scientist
      • 11898
      Well, if it is really badly worn (like mine was) the crank will move back and forth a noticeable amount. To measure it, you need to put a dial indicator on the end of the crank and see how much it moves.
      Replacing all the main bearings is just a matter of unbolting the bearing caps, pulling the crank out and putting new ones in. I would replace the rod bearings while you were at it. I can't remember is the main cap bolts are reusable, but the rod cap bolts are not, so you will need new ones of those as well.
