crap, i really don't want to dig in this engine again
m42 knocking
1985 325e - wrecked :( (being fixed and full paint job)
http://www.r3vlimited.com/board/showthread.php?t=197989
the horrible day
http://www.r3vlimited.com/board/showthread.php?t=210850
1991 318i - in process of being made a DD
http://www.r3vlimited.com/board/showthread.php?t=219793 -
Generally oil pumps stop working after the clearance between the lobes of the "sprocket" and the out case get too wide. they should only be a few thousandths of an inch. Any more and the pump can't compress the oil and pump it. Easy check would be to throw an oil pressure gauge on and see what the pressure is. Should be somewhere around 63 psi at higher engine speeds.Comment
ok so i'll check the oil pressure i guess when i get the chancesigpic
the horrible day
http://www.r3vlimited.com/board/showthread.php?t=219793Comment
but if the oil pressure is low wouldn't the oil light go on?sigpic
the horrible day
Nope my car ticked like a muthafucker i installed new vw lifters timing was correct. imy car wouldnt tick all the time hust most of the time. Everythung was nrw except the oil pump i mean the engine had over 400k. Installed low mileage engine no more tickStrategic nw e30 commandOriginally posted by bmwm42PNW vulture pm me for partsComment
so i started to go for the oil pump, taking everything off and stuff and found out that my main bearing took a dump on me and my 4th rod bearing spun, this is lame. well i guess here comes a full rebuild of my m42 lolsigpic
the horrible day
