M42 died on the highway - Solved
  • roguetoaster
    Biggus Tippus
    • 7830
    On startup at the start of the trip the cluster lights were lightly flickering, it quit doing this after 45 seconds or so. Driving down the highway car was acting normal. ABS light came on, check engine light came on 1-2 minutes later. One minute after that the car is acting like it is missing spark. Immediately after that the speedo stops registering correct speed, tach goes on/off intermittently, lights on IC flash dimly. 45 seconds or so later the engine is producing no power. I have pulled over at this point, shut car off, try to start, no crank. Stomp test 1231 DME Main Relay/Voltage issue. Lights, radio, clock all working fine. Wanted to check relays, fuses, etc, but position on shoulder prohibits this. Walked the ~1.5 miles to home.
    So, DME relay failure, DME failure, fusible link or something I am overlooking? Let me know your experiences/thoughts if any.
  • jntar
    • 459
    Battery could have a bad cell. Alternator could have shorted out. Relay could be bad. Ect...It's in the charging system somewhere. Start with the cheap items (Take battery to autoparts to test for dead cell) then go from there.
    1231 - Battery Voltage / DME Main Relay error code can mean that battery voltage is out of range (either too high or too low), or that battery was disconnected. Test charging system and /or battery to find problem cause.
    M42 turbo build.
    http://www.r3vlimited.com/board/showthread.php?t=301330
    • roguetoaster
      Biggus Tippus
      • 7830
      While it is possible that it is the alternator/battery that would surprise me as there isn't even the faintest hint of a crank from the starter (and it's not too old of a starter) and the other electronics work fine, lights (even high beams), etc. Other ideas?
      I will start with the simple things as soon as I get it home of course. With the relay being #1 on the list.
      • jntar
        • 459
        Your radio and ect can still work, but with a shorted cell in the battery when you attempt to pull amperage with starting it would fall on it's face and not do anything. Give the battery a test, it's the cheapest place to start.
        M42 turbo build.
        • roguetoaster
          Biggus Tippus
          • 7830
          Thoughts on how this would cause the engine to shut down in such a progressive manner at highway speeds?
          • Dj Buttchug
            • Jun 2010
            • 7678
            no more spark to ignite fuel. Its in the charging system. cars do weird things when the electrical system isnt working right.
            Turbo M42 Build Thread :Here
            Ig:ryno_pzk
            I like the tuna here.
            Originally posted by lambo
            • future rs
              • Aug 2012
              • 514
              Certain components require more amperage to operate. The loss of power coupled with the alternator supplying power as well can cause a progressive power loss.
              I had a cooling fan rub a hole in the corner of a battery and had a very similar experience. As the battery lost the ability to keep up the alternator was supplying enough to keep things going for a bit until it was too much draw to keep up with.
              • roguetoaster
                Biggus Tippus
                • 7830
                Update
                Initial thoughts were failure of alternator caused battery to discharge, thus no spark, yadda, yadda, yadda.
                Changed alternator to working unit from spare car, at the same time changed alternator to engine ground strap as the old one was corroded and casing was damaged. Inspected grounds. Checked voltage on battery, 6.4v with battery ground strap unhooked, .4v with strap connected!?! Makes my more clear headed brother think there is hot ground, makes sense. Pulled all fuses and attempted to hook up a remote battery for a jump, only to be treated to a some very concerning sparks when just touching the second cable to the terminal/connector. Double, triple, and quadruple checked that the cables were not crossed or confused and that ground was solidly in place. Tried touching connections again with battery out of loop, same result. Checked for continuity between rear positive battery cable and front pole mount, all good. Going to inspect fusible link and who knows what else, but quite stumped right now.
                Yes, before you ask, the jumping sequence was car positive terminal then car negative battery cable to body unhooked from battery.
                • lolcantturn
                  • 4588
                  try a new dme ?
                  Originally posted by TSI
                  OEM+
                  • kwill22
                    • Apr 2009
                    • 962
                    I thought if the battery registered higher when disconnected and the voltage dropped dramatically like that when connected it meant the battery is bad.
                    DENY IGNORANCE!
                    Schwarz 325-totaled
                    brilliantrot 318i-daily
                    Originally posted by mkcman17
                    don't think your hamster wheels are fast now. you will still have to give up when trying to pass that V6 odyssey to make your offramp.
                    • roguetoaster
                      Biggus Tippus
                      • 7830
                      Solved
                      Apparently the brushes in the alternator were worn down to nothing/had a random failure, caused low output, drained battery and stopped car. Swapped in the other alternator only to experience some other sort of failure (the sparking, probably due to bad resistor or something of the sort). Took brushes out of that alternator, installed in first (one in the car when it died) alternator, jumped, all was well.
                      This is omitting the obvious steps of isolating what component was causing the issue, but it's solved so who really cares. A side note, for several days before the car died it felt as if it was low on power, with the alternator fixed it feels back to its peppy self.
