M42 engine install
  • Beemerdan
    • Nov 2012
    • 192
    M42 engine install
    I purchased a 1991 318i back in the fall with the engine pulled out due to bad crank. I just bought a long block to put in it, which I will be picking up tomorrow. Just wondering if there is anything special I need to be careful of when I put the engine in? Any tips from guys that have done it?
    I have done engine drops before, just not in a BMW, so any tips or suggestions would be appreciated!
    Thanks!
    Dan
  • Simon S
    • Oct 2004
    • 3758
    Sounds like you'll be fine.
    Working on e30s is like working on an old chebby..
    -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
    • Dj Buttchug
      • Jun 2010
      • 7673
      pretty much this ^
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • Beemerdan
        • Nov 2012
        • 192
        Thanks guys!
        that's what I figured, but though I would ask just in case.
        Thanks!
        Dan
        • willworkfore30s
          • Aug 2011
          • 1090
          Replace hard to get to seals before you install! Putting an m42 in is no biggie. I put mine in as a first timer by myself so if you've done swaps before I think you will be all good!
          • Beemerdan
            • Nov 2012
            • 192
            Yeah I'm planning on doing all that before the drop, including crank bearings, to replace the 180 trust bearing.
            Thanks!
            Dan
