M42 Fuel issues/ goes from 30 to 0PSI at WOT
  • monty23psk
    • Mar 2008
    • 1289
    #31
    Could it be #5?
    http://www.realoem.com/bmw/showparts...34&hg=61&fg=15
    Alex 88 m5 | 91 318is | 19 Subaru Ascent
    BMW Tool Rentals & Fender Roller
    • Bimmian89
      • May 2012
      • 170
      #32
      No, thats for the head lights.. So it says..
      Check out my build thread!! :p
      http://www.r3vlimited.com/board/showthread.php?t=288383
      • monty23psk
        • Mar 2008
        • 1289
        #33
        #4 is for headlight. Only one way to find out is to order since it is cheap. What throws me of is that it states quantity 2 for the car.
        • Bimmian89
          • May 2012
          • 170
          #34
          Problem still persists with a rigged connector, starting to think there is a short in the wire or something. Going to check voltage while driving tonight, as well jump it straight from the battery and drive. The pump is only getting about 11.3 V while idle, stays the same when you rev it. I was thinking the pump should be around 13-14 volts though, is that correct? I sit in the back while my dad drives it and when it starts acting crazy you can hear the pump cutting off and on..
