M20 crank bearings in M42?
  • Beemerdan
    • Nov 2012
    • 192
    I just received the crank bearing that I ordered from BMA and they sent me m20 bearings. I looked up the numbers on their website and it looks like they sell them as the same thing. I have heard of using m20 bearings in the M42, but just wanted to check with you guys to see if this is normal? Any problems with doing this?
    Thanks!
    Dan
  • wazzu70
    • Jan 2005
    • 1143
    You need to have the main caps machined to use the M20 bearings. You need M42/M50 bearings.
    -Nick
    M42 on VEMS
    • Rocla
      • 922
      If m20 bearings are for 3/88 or newer block they are same as m42 and m50 ones.
      IIRC new m20, m42 and m50 have two holding claws in bearing while older ones only have one.
      Current:
      BMW 320i 2d 2.0 m20 -88
      BMW 325i Cabriolet 2.5 m50 -88
      BMW 316i touring 1.6 m40 -90
      BMW 320i 4d 2,2 m54 -01
      • Beemerdan
        • Nov 2012
        • 192
        Just looked at the package again, it says they are for m20/m50/m52/m21d/m51. Also it looks like the holding claws match up right. The block and their bearings have on claw, while the main caps and their bearings both have two.
        • shEck3lls0
          • Jan 2011
          • 1154
          I used m20 bearings in my m42 rebuild.... Let me look back on exactly what I used/did.
          1989 Alpine 325is 2dr m50 swapped
          Build Thread:
          Current ongoing build. Check it out!
          1991 318is 4dr rallycross
          Rallycross Build Thread.
          1991 Alpine 318is coupe - sold
          • wazzu70
            • Jan 2005
            • 1143
            This is correct. I forgot it was only the early M20 bearings that are not compatible!
            -Nick
            M42 on VEMS
