m42 into a 318i
  • Joe318is
    • Sep 2005
    • 6451
    #31
    Originally posted by FredK
    I believe early cars had a different, rectangular (as opposed to round) C101, so he'd have to make a wiring adapter. It shouldn't be too hard to figure out.
    They still have some sort of plug for the engine harness. I think you are correct
    Originally posted by vlad
    • Mr Deagle
      • 1121
      #32
      NOTE: the stuff below is for an E to I swap, but it may pertain to a m10 to m42 swap
      Round Connector >> Rectangle Connector
      1 >> 1
      2 >> 2
      3 >> 3 (not used at all)
      4 >> 4
      5 >> 16
      6 >> 6
      7 >> 10
      8 >> Not used
      9 >> Speed signal (run wire to C104 in glovebox (black wire))
      10>> 15
      11>> 17
      12>> Not Used
      13>> 7
      14>> Not Used
      15>> Not Used
      16>> 11
      17>> Not Used
      18>> 8
      19>> Not Used
      20>> Run to a good ground
      • RRRR
        • Aug 2007
        • 32
        #33
        Originally posted by ZiMMie
        ull be a fool to boost the m42 instend of the m10. keep the m10. Very strong motors.
        ZiMMie
        Love the wheels you run in your sig. :bow:
        What are they and possible to still get used ones?
        • Stu
          • 4083
          #34
          Contact Jenny Morgan (CCA Tech Advisor)....She did a complete M42 swap on an early '82 or '83 build-date 318i 15 years ago. She knows more about M42's than anyone on this board. : )
          • RRRR
            • Aug 2007
            • 32
            #35
            Searched but cant locate her - anyone has her link?
            • isamemon
              • Jan 2009
              • 257
              #36
              all somewhat related.... not try8ing to get off subject but I saw the part about trannys and m42's
              so I have two 91's with m42's. they are two months apart on build dates. the early one is a coupe, the later a vert. tow different tranny builders
              one says getrig, and I could have sworn, the last time I was undr the cais it I could have sworn it said hect...maybe I was looking at the wrong thing
              late at night when I looked, just got it a few days ago
              Ill have to climb under them today and look again
              but is this right
              also the final drive says 4.1 but not have the "S" in fornt of it
              so I guess my is does nto have limited slip, but I was told when I bought it , that it did
