Opinions needed on M20 radiator
  • shameson
    • Jun 2012
    • 1507
    Okay so the PO had an m20 radiator installed and the fan removed. With the m20 radiator being a bit larger than the m42 one, he said that it will be sufficient at keeping the engine cool w/o needing a fan.
    He hasn't had issues w/ overheating and I haven't either but it was winter and just now spring so it's too cold to tell. Take in mind summer here in Washington is anywhere from 70-90 degrees. Won't take many long trips with it throughout the year, furthest would be 3hrs to e30 picnic in Seattle.
    I'm curious as to whether it will be fine just with the larger radiator or if it needs a fan. PO knows a lot about m42s so I trust him but I wanted a second opinion.
    '84 Alpine 325e (Gone)
    '91 Alpine 318i (Gone) Click Here
    '92 Alpine 325i Cabrio (Gone) Click Here
    '91 Alpine 318is
  • Danny
    • 14216
    Does it still have the aux fan in front of the rad?
    • shameson
      • Jun 2012
      • 1507
      Ya he installed it with an auxiliary fan
      '91 Alpine 318is
      • Danny
        • 14216
        That means the engine still has a fan, just no mechanically operated fan. You'll be fine.
        • shameson
          • Jun 2012
          • 1507
          Ok good to know. Thanks man! It's nice having that extra work for work
          '91 Alpine 318is
          • roguetoaster
            Biggus Tippus
            • 7797
            The better question is does the aux fan work? You should test it when the car is warm, then at idle turn on the A/C, and the fan should come on. If not, replace with a Volvo fan or similar for peace of mind.
