Interest in custom Fan Shroud for 16 inch Spal Fan
  • 5m1dy
    • Sep 2012
    • 13
    I recently bought a 16 inch fan and have worked out how to wire it up so that it the new fan logic resembles the below table.
    Temperature less than 91ºC and AC Switch Off
    No fans on
    Temperature less than 91ºC and AC Switch On
    AC Aux fan on
    Temperature between 91ºC and 99ºC
    Spal Fan on
    Temperature above 99ºC
    Both fans on
    I see most people mount these fans directly to the radiator. However, I don't want to poke the zip tie things through my fins. I also think it limits how well the fan actually draws air through the radiator.
    The shroud will be cut/potentially laser cut out of a sheet of aluminium.
    The Spal fan will mount directly to the shroud using Spal's provided hardware.
    The shroud will bolt up to the 4 holes at the top and bottom of the M42 radiator, which will make it stand off the fins by a few mm, which should make the fan much more efficient, and probably look quite good in the engine bay.
    Just wanted to throw this idea up here.
    If anyone is interested in one for their M42 PM me.
    I'm in Australia, so it is probably cost prohibitive for me to make them and ship them to the US, but we'll see.
  • wazzu70
    • Jan 2005
    • 1143
    Sounds like a good idea. Unfortunately its probably cost prohibitive to ship a large sheet like that to the US.
    I send packages to Austraila regularly. Its not cheap!
    There are probably a lot of people in AUS who could use one though.
    -Nick
    M42 on VEMS
