Squealing.
  • Steve547i
    • 130
    Squealing.
    In the mornings or when the car is cold my m42 will squeal horribly in first until about 3.5 when i shift. It only does it once and it is incredibly loud.
    Idler pulley or something of that nature?
  • pmat
    • Nov 2012
    • 174
    belts tight enough? mine does the exact same thing, and its the belt tension.
    318is, m50tu g240 s3.46
    • Steve547i
      • 130
      Will czech it, thanks
      • Steve547i
        • 130
        I tighten the alternator belt as it seemed pretty loose. Ill see what happens. Thanks for the tip
        • Nick_S
          • Apr 2011
          • 3658
          Mine did that. Loose alternator belt was all it was.
          91 318is M50 swapped
          05 Honda Pilot
          24V swap thread
          • roguetoaster
            Biggus Tippus
            • 7830
            If the squealing persists after adjusting belts I would suspect the A/C compressors clutch.
            • Steve547i
              • 130
              All set with the squealing. Multiple start ups and cold mornings and it's gone away. I love the adjustment system on these and m20 alternators.
