Lower timing cover gasket
  • Beemerdan
    • Nov 2012
    • 192
    I am replacing all the lower gaskets on my engine before dropping it into the car. The gasket set came with two gaskets for the lower timing cover (between the inner cover and block), one metal and one paper. Are both supposed to be used?
    Thanks!
  • vpilarrt
    • Jun 2006
    • 2096
    The M42 in the E36 got the metal one starting in model year '94. Previous to that they (and the E30) had the paper one. The later model inner cover was different also so I would use the paper one. Whatever gasket set you got probably just covered both.
    • bmwm42
      • 6300
      Don't use the paper crap use the right stuff or honda bond
      Originally posted by bmwm42
      PNW vulture pm me for parts
      Strategic nw e30 command
      • Beemerdan
        • Nov 2012
        • 192
        Ok, sweet.
        What do you mean by "the right stuff"?
        • bmwm42
          • 6300
          That is the name of the gasket maker made by permatex about 15 bucks a bottle readily avail at your local parts store
          • Dj Buttchug
            • Jun 2010
            • 7677
            you can use the paper gasket if you want to. just copper coat it first. otherwise gasket maker
            Turbo M42 Build Thread :Here
            Ig:ryno_pzk
            I like the tuna here.
            Originally posted by lambo
