Oil weight?!
  • JonnyOg
    • Sep 2012
    • 191
    Oil weight?!
    Tired of searching and finding tons of different answers, what oil weight should I use?
    B.C. climate, similar to washington. Running 15-40 rotella and my car sounds like shiiiet on startup. What are you guys running?
  • jntar
    • 459
    Started off running 10-40 Mobil 1 high mileage, but I found that 5-40 Castrol Edge (BMW blend) was cheaper and worked just as well.
    When you say sounds like shit do you mean noisy? Rattle sound? Might be time to check the timing chain/guides/gears/tensioner.
    M42 turbo build.
    http://www.r3vlimited.com/board/showthread.php?t=301330
    • JonnyOg
      • Sep 2012
      • 191
      Yea just changed the tensioner 5 minutes ago actually. Yea sounded like a diesel on startup. I'll probably just go with a 10-40 I guess.
      • Tisoc
        • Jul 2011
        • 249
        Diesel? No bueno, your timing is off. Have you checked your cam gears? Other chain components may be toast as well.
        • nickmcc92
          • Dec 2012
          • 442
          I use shell rotella t6 5w-40 here in SoCal and my car sounds the same on start up
          • JonnyOg
            • Sep 2012
            • 191
            After the new tensioner it has stopped this noise.
            • nickmcc92
              • Dec 2012
              • 442
              Was it a clacking type of noise on start up?
              Did it get rid of the Diesel engine?
              • Threehz
                • 1480
                10-30 (or 10-40) Castrol GTX is the what your M42 craves.
                Different strokes for different folks.
                • Nick_S
                  • Apr 2011
                  • 3658
                  I always used 10w-40 but last time tried 20w-50. On chilly mornings it's definitely louder and get a lot more valve tick till it warms up. Will be switching back to 10w-40 soon.
                  91 318is M50 swapped
                  05 Honda Pilot
                  24V swap thread
                  • roguetoaster
                    Biggus Tippus
                    • 7830
                    My M42 seems to be happiest with 10w-40, in either Castrol Sytec or Rotella T. I have noted that in plain appearance those both seem to have heavier static viscosity vs. other synthetic 10w-40s.
                    • M3Philipp
                      • Jul 2011
                      • 278
                      10w40 for the M42.
                      If you live in a hot area somewhere on this planet, may even use 10w50, 20w50, 10w60.
                      • kwill22
                        • Apr 2009
                        • 962
                        I use 0w-40. Works fine and 5w-40 worked good also. No problems for me
                        But you're are in a completely different climate than me
                        DENY IGNORANCE!
                        Schwarz 325-totaled
                        brilliantrot 318i-daily
                        Originally posted by mkcman17
                        don't think your hamster wheels are fast now. you will still have to give up when trying to pass that V6 odyssey to make your offramp.
                        • sfinsf
                          • 246
                          210k on clock, new tensioner, running 20w-50 and peeps have said it's the quietest M42 they've heard. Also seems to disappear less. when I was trying different oils, any of the 10's would disappear faster, never tried anything less than 10w.
                          I was adding 1/2 quart every wk or so with regular driving with the 20-50 it's more like every 2wks.
                          oh and these were all dino's
                          • irish44j
                            • 2763
                            I'm running Rotella T6 5w40 and mine isn't noisy on startup (well, it is because I have solid motor mounts, but the ENGINE itself isn't noisy), and smooth as an M42 can be when moving. I also don't lose any oil at all between changes.
                            Stage rally/rallycross e30 build/competition journal
                            Track/street e21 build
                            visit Condor Speed Shop
                            visit Motorsport Hardware
                            [FONT="Franklin Gothic Medium"] 1985 318i/M50 Rally Car - 1988 Porsche 924S - 2005 Sequoia tow pig - 2018 GTI
                            • goinstrong
                              • Jul 2008
                              • 215
                              10/40 for sure...Castrol GTX is always a good choice!
