M44 in an e30? e21?
  • E30 Wagen
    • Jul 2005
    • 3428
    M44 in an e30? e21?
    How easily does the M44 from later e36's mount onto the e30 subframe?
    My Feedback
  • roguetoaster
    Biggus Tippus
    • 7830
    Just based on simple guessing I would imagine it would be a cinch. Engine arms might be different, but otherwise the fitment should be easy. RealOEM would probably confirm that.
    Of course the question would be why M44, unless you want forced induction?
    • Wanganstyle
      • 2828
      Swap to m42 front sump oil pan; then install. Adapting wiring should be quite easy considering how easy a e36 6 cylinder swap is to handle
      Sent from my GT-N7100 using Tapatalk 2
      • E30 Wagen
        • Jul 2005
        • 3428
        Any more thoughts on this? What about fitting one in an e21?
        My Feedback
        • wazzu70
          • Jan 2005
          • 1143
          Its no different than what it takes to fit an M42. Use whatever pan the swap uses (e30 front sump/e36 rear sump) and use the E30 manifold if the E36 does not fit.
          -Nick
          M42 on VEMS
