Stupid m42! Didn't start!
  • salvuhdor
    • Jan 2013
    • 445
    Okay keeping it simple. 1991 318is m42
    Car ran perfectly fine but some rattle noise. One rail guide was shot.
    I did a overhaul. Removed timing covers and replaced all parts from water pump to all the rail guides and did all gaskets.
    I had the alignment tool for the cam shafts and bellhousing. I installed the chain, the tensioner, guides etc etc.
    Okay now bolted everything up to torque (crankshaft bolt at +250lbs) and made sure hoses were good.
    Car cranks and starts for no more than one or two seconds and dies, I hear like a knocking noise. It sounds like it hits something and stops. After numerous tries I gave up.
    I will be back out there tomorrow trying to figure it out. Is there any way I could adjust timing on this car?
    I've taken a video Which i will post here soon. Any help would gladly be appreciated!
  • salvuhdor
    • Jan 2013
    • 445
    • salvuhdor
      • Jan 2013
      • 445
      Some droplets of water was found inside my engine compartment.
      I have incorrectly installed the mess under the intake. It was a pain installing them, and now tomorrow I will need to take off the manifold and triple check. About 99% sure it was an incorrect hose.
      • bmwm42
        • 6300
        Pics of you cam gears would help
        Originally posted by bmwm42
        PNW vulture pm me for parts
        Strategic nw e30 command
        • roguetoaster
          Biggus Tippus
          • 7830
          Fingers crossed for that being the issue, but that whump I thought I was hearing in the video sounds like a timing issue. It's well worth checking that you have TDC 1 with the pistons and vibration dampener and your cams/gears are aligned (and you don't have to take much off, just two plugs and the VC).
          • salvuhdor
            • Jan 2013
            • 445
            My Father was talking about this. He helped me put the engine back together. I actually have photos of it. The vibration damper has a gap which aligned to the arrow on the engine cover, we believed that we did align it but we still check tomorrow for sure and take pictures.
            As for the cam gears, I will snap a shot or two tomorrow afternoon as well.
            • Dj Buttchug
              • Jun 2010
              • 7686
              if you aligned the timing mark to the gap on the tone wheel the timing is wrong. You have to align the timing arrow on the oil filter housing with a stamped notch. Its sometimes very hard to see.
              You are off on the crank. 100% sure.
              Turbo M42 Build Thread :Here
              Ig:ryno_pzk
              I like the tuna here.
              Originally posted by lambo
              • salvuhdor
                • Jan 2013
                • 445
                ^^^ this!
                Thanks I've been searching online whether or not it was aligned properly!
                I'm am going to do this in about 3 hours
                • salvuhdor
                  • Jan 2013
                  • 445
                  Everything is aligned fellas but it doesn't start... Could it be a wrong hose connected to the intake manifold that would made the engine act this way on start up
                  • bmwm42
                    • 6300
                    the only reason it wouldnt start if all your timing marks align is if you have a massive vac leak. could also be spark plug wires not in the correct order
                    • mr ilia
                      • May 2011
                      • 582
                      Cam and crank sensor plugs were switched?
                      • salvuhdor
                        • Jan 2013
                        • 445
                        so here is what I will do.
                        -Recheck all hoses and connections under the intake
                        -Carefully check my spark plug wire connections make sure they are in the right cylinder
                        -Check cam shaft, crank shaft sensor connections
                        -Then check timing chain sprockets, would it be a big deal if I bolted in the hex bolt a little off to the side on the slots for the sprockets instead of directly in the smack dab middle?
                        • roguetoaster
                          Biggus Tippus
                          • 7830
                          The first three sound like perfectly reasonable steps.
                          If the bolts are not centered the car should start, but I would center them. It's not too hard to do while you are there. If they have arrows put those up and IIRC, the little dowels are down and to the left in that orientation (if your gears have no arrows).
                          • salvuhdor
                            • Jan 2013
                            • 445
                            My freakin spark plugs... Wow
                            Car starts now!!!
                            Time to give it a wax, alignment, install my fogs, euro smilies, mtech steering wheel, paint and install my "is" lip... Ahh soo happy!
                            • mr ilia
                              • May 2011
                              • 582
                              What was exactly wrong? Spark plug wires got mixed up?
