M42 stalling.
  • loganwept
    • Aug 2012
    • 153
    M42 stalling.
    Hi so I was driving my e30 to Oakland airport and it was fine. On the way back it started losing power. It got to the point when when i was on the freeway flooring it going 55. It started hesitating and throwing a CEL. I was almost home when It started bucking and would barley go from a stop. I died in my driveway. I got a stomp test code of 1222.
    I cleaned my ICV my AFM and my throttle body.
    Gonna pull the plugs and look to see what they look like.
    Good question is, is my fuel pump supposed to be running while the key is turned to the AUX position? If so. It's not may be dead.
    I have a new o2 sensor.
    New plugs.
    I also have
    A noisy fuel pump
    Thanks in advance and sorry for my scatter brained ness
    Update: I put a different AFM on the car. Still wouldn't start. Still throwing the 1215 code.
    I unhooked the battery and reset the code still no start but now it's not throwing the 1215 code... I'm stumped.
    leave me some feedback if you've bought from me or I've bought your stuff!!
    http://www.r3vlimited.com/board/show...09#post3438509
  • jrobie79
    • Mar 2006
    • 2522
    it might still make noise and be on its way out, thats what happened to my FP. I put an aftermarket from TREperformance, no issues in the past 2 years
    1991 318i ---- 308K - retired
    • loganwept
      • Aug 2012
      • 153
      Cool thanks.
      UPDATE!
      It's no longer throwing a 1222 code. Now it won't start but sputter while turning over. And it's throwing a 1215 code.
      • loganwept
        • Aug 2012
        • 153
        No other inputs? I just bought a fuel pump so ill throw that at it and see.
        • Bmr
          • Jul 2009
          • 322
          you replace fuel filter?
          • loganwept
            • Aug 2012
            • 153
            Yeah I ddid the pump, pump filter and in line filter. Still nothing.
            Waiting on an AFM from another member on here to actually ship then ill see.
            • loganwept
              • Aug 2012
              • 153
              Bump
              • bmwman91
                • Oct 2004
                • 3128
                Can you hear the fuel pump running? Do you get 12v on the small terminal block above the main 12v block on the firewall? I am betting on a broken fusible link.
                Transaction Feedback: LINK
                • loganwept
                  • Aug 2012
                  • 153
                  The pump is running. Im gonna check the relays.
                  • loganwept
                    • Aug 2012
                    • 153
                    Turned out to be a clogged catalytic converter... Stupid lo car problems. Scraping in speed bumps. Hollowed it out not my car sounds like garbage.
