Not understanding the HQ Autosport kits http://www.hqautosport.com/products1.html
COP conversion explanation for a noob
From the website:
What are the benefits?
Installing this kit gives you a cleaner, simpler engine bay,
eliminates the lengthy and unsightly spark plug wires, and
removes multiple points of failure in the ignition system. Many
owners report improved throttle response, a smoother idle, and
elimination of ignition misses. If you have or suspect a defective
coil, this kit is significantly less expensive than replacing the OEM
coils and wires.
That's simply not true, the conversion involves installing 4 coils essentially inverted in the valve cover well. Quick diagram of 1 cylinder COP setup looking from the front, from the valve cover down.
---_Coil _---
| Connector | <- valve cover
[ ---- ""---- ] <- cylinder head
[ Spark plug ]
Oh ok right on. Yea I'm finally looking at more money in my pocket then having it all disappear after payday, so I'm looking to get a bit more horsepower, but I'm going to dyno it stock, then do it after a few mods to see how much I have gained, then again I'm not looking to beat a Ferrari just for a bit more power because I love the motor and car overall
