Overheating, Switch To Electric Fan or Replace Fan Clutch
  • dr.gonzo
    • Nov 2009
    • 206
    Car is overheating while idling or in stop in go. I heard the fan clutch screech when I started the car and figured the fan clutch had gone. Does an electric fan make much of a difference on the M42? I know for the M20 it doesn't make much sense but on a smaller motor I think it would, ALso what is the parts number and a decent DIY
    www.roadreview.net
  • reelizmpro
    • 9529
    Is your aux fan not working? I know by now many of them have blown resistor packs and stop working but if it's there why not use it? Get it fixed and while you're in there clear the condenser of debris. I think on a 4 cylinder, it's worth it to remove the fan clutch and install an electric puller fan if you are trying to free up the engine but if you daily the car and want reliable cooling...get a good fan clutch.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • dr.gonzo
      • Nov 2009
      • 206
      I'm not sure about the aux fan, I haven't even tried to diagnose it yet since I had experience with previous e30s and recognized the fan screetch.
      Reliability is a concern especially since I will be moving to warmer climate
      www.roadreview.net
      • dr.gonzo
        • Nov 2009
        • 206
        Would this be an appropriate replacement? http://www.ecstuning.com/BMW-E30-318...lutch/ES24490/
        www.roadreview.net
        • roguetoaster
          Biggus Tippus
          • 7830
          Sure, that should work. Or you can go with a Volvo fan (850, 960, others) from the junkyard, or a new fan of many types if you prefer electric. Further, if you want a nice looking swap someone (maybe ECS) sells a cap to go over the threads removing the clutch would leave. As to swap DIYs, they exist here, on BF, and M42Club, should be easy to find what you want to know.
          Have you done the test on the fan clutch yet?
          • dr.gonzo
            • Nov 2009
            • 206
            Tested fan clutch and it was bad. I decided to just get another clutch since the car will be dealing with Arizona weather sooner or later
            Sent from my SGH-M919 using Tapatalk
            www.roadreview.net
            • slowmoe30
              • Nov 2017
              • 30
              To test the aux fan go to the temp switch at the radiator, and short two switch pins together when the car electronics are on.
              GRN/BLK to BRN/BLK fires low temp mode
              GRN/BLK to BLK fires high temp mode
              If high temp mode works, fan works
              If low temp mode works, fan and resistor work
              If only high temp works, fan works but not the resistor
