318is cold start idle issue?
  • e dubb
    • 16
    My 318is has a cold start issue that I am trying to sort. When the car is cold and it's started it won't hold an idle. I have to keep the throttle pressed for a minute or two until it's warmed up. If I let off the throttle before it's warmed up it will just die out. Now once it's warmed up a little it runs/drives and idles great! Has anyone else experienced this?
  • greanthumb
    • 1992
    I once had an issue similar to this. It will only occur when u first start the vehicle after cooling down/not running for awhile.
    There is a small plug located behind the plastic harness wire housing along the firewall. It's used/plugged in only for aftermarket cat converters I believe. Anyway...not sure if this is your issue.... Might be worth a try/look. It should NOT be plugged in w stock cat
    91 318is...DD:finger:/85 325es SOLD/91 318is RIP
    Originally posted by naplesE30
    Must stop clicking on Norwegian threads. Makes me wanna punch my car in da mouf.
    Originally posted by einstein57
    My tranny sounds like a blender full of walnuts. So I added sound deadner to the tunnel and put in a louder stereo. Am I doing it right?
    Castro Motorsport/E30 specialist
    North Hollywood, Ca. 818 310-2497
