Help trace oil leak
  • TroyShark
    • Oct 2012
    • 195
    Help trace oil leak
    Im getting some oil puddle that builds up above the plate the holds the alternator. Im trying to trace the leak but am having trouble. I already replaced the oil filter housing gasket twice so I'm hoping it is not that. Anyone have any ideas?
    Thanks in advance
    photo-4 by Troy Shark, on Flickr
    photo-3 by Troy Shark, on Flickr
  • Gerta
    • Sep 2009
    • 2119
    Oil filter housing gasket or oil pressure sender o ring... Did you replace the o rings when you replaced the gasket?
    Sent from my SCH-I545 using Tapatalk
    Parts Collector and Former Houndstooth interior junkie.
    • TroyShark
      • Oct 2012
      • 195
      I did not replace the o-ring. Thanks for the advice.
      • Gerta
        • Sep 2009
        • 2119
        Check RealOem for the part number....
        • roguetoaster
          Biggus Tippus
          • 7830
          You might also check the sensor itself. The plastic can crack allowing oil to seep out of the bottom (how it gets to the plastic part of the sensor is a mystery to me).
          • oldmann
            • 265
            I had a similar leak, mine was leaking oil out of the terminals, in the plug. Replaced sender, no more leak.
            • Stevoyayaya3
              • Aug 2013
              • 315
              Bump for the same leak I have lol
              • G-Man
                • 479
                Since mine is leaking in the same spot, I did a search on oil leak and found this post.
                The above pics look exactly where the oil is on my 318i so I'll be ordering an oil housing gasket an O-ring from Blunt.
                G-Man
                74 2002tii (many mods)
                86 325 (sold)
                88 325is (sold)
                89 325i (totaled)
                91 318is (parted out)
                91 318i
                98 Tacoma Prerunner (parts hauler)
