Steering rack leaking fluid
  • Lee22
    • Feb 2012
    • 400
    tried searching but didn't come up with much info. which route do most go when they have a steering rack leak? looks like OEM racks retail for $940+. My BMW employee discount is good for $600 for the ZF brand. Any have luck with the cheaper aftermarket brands in the long run?
  • jntar
    • 459
    I'll probably be chastised for this but I've been running an advanced auto parts e36 rack for over a year. It's the correct lock to lock as the '96+ rack and was only $158.
    M42 turbo build.
    http://www.r3vlimited.com/board/showthread.php?t=301330
    • roguetoaster
      Biggus Tippus
      • 7830
      Well, you can skip power steering ($0 to delete, or more to do it "right"), replace it with a used rack E30 or E36 (<$100) or rebuild it with a rackdoctor or similar kit ($?).
      All are good options, but it all comes down to budget and what you use the car for.
      • bmwman91
        • Oct 2004
        • 3134
        Dump the awful E30 rack. They blow end seals like crazy and are slow as hell.
        The Z3 1.9L rack is a fairly easy swap, has a 2.7 turn ratio (vs 4 stock) and I was able to find a good condition used one for $200. 70k miles later it is still good. You need to stack some washers to get it snug between the subframe tabs, bend the metal parts of the PS hoses a tiny bit and file the column's hole in the firewall a little, but it is an afternoon job.
        Transaction Feedback: LINK
        • Lee22
          • Feb 2012
          • 400
          my car has 250,000 miles on it, is mostly stock and is driven in the city and some freeway. this is not a car that I use for much hard driving, and occasional Canyon run but that's it
          • Lee22
            • Feb 2012
            • 400
            Its really odd, since i topped off the power steering fluid (it was half empty from leaking) the leak has virtually stopped.
            • roguetoaster
              Biggus Tippus
              • 7830
              Where was it leaking from, the rack or one of the lines?
              • Lee22
                • Feb 2012
                • 400
                the line going to the reservoir shows some moisture, but it was definitely leaking from the lower part of the rack, i believe from the area where the seals are
