M42 head question
  • Austin30
    • 61
    M42 head question
    I know this May be a stupid question but I thought I may ask sense I bought this head. I have a 91 318is that the head cracked on here a few mounts ago. So I bought a head from a fellow on here but it's was out if a 318i.
    Is the m42 head the same for the 318is and the 318i. I didn't know if the( is )may have bigger valve such as a 7mm and the ( I ) had 6mm valves.
    91 318is
    94 accord
    96 mustang / workin progress
    sigpicE30 enthusiast
  • wazzu70
    • Jan 2005
    • 1143
    Yes they are the same. Even if the heads have the different valve sizes it wont matter.
    -Nick
    M42 on VEMS
    • Austin30
      • 61
      Thanks man. I've got a few more questions. I'm getting the head rebuilt a a local shop so while waiting I'm gonna buy my head bolts head gaskets and ext. Does anyone recomend a specific head gasket and head bolts. I was gonna but all parts off of blunt tech. Is that a good site to buy bmw parts. I just don't want to go oem because it's so expensive
      91 318is
      94 accord
      • Gerta
        • Sep 2009
        • 2119
        Yes, Blunttech is a great place to buy parts. Steve is an enthusiast with several E30's including a 318is. steve@blunttech.com for a direct email to the man.
        You can check part #'s etc ... on www.realoem.com
        Gerta
        Parts Collector and Former Houndstooth interior junkie.
        • Austin30
          • 61
          Hold on I'll send the link to the parts I was looking at and see what you think. Cause it would be a shame to put this head on with these parts an they not hold up.
          91 318is
          94 accord
          • kwill22
            • Apr 2009
            • 962
            Get a goetz head gasket and stock bolts are fine. Profile gasket also
            DENY IGNORANCE!
            Schwarz 325-totaled
            brilliantrot 318i-daily
            Originally posted by mkcman17
            don't think your hamster wheels are fast now. you will still have to give up when trying to pass that V6 odyssey to make your offramp.
            • Austin30
              • 61
              here is the two links I was looking to buy and see what yall think.
              links:
              91 318is
              94 accord
              • Austin30
                • 61
                and what do you mean by profile gaskets. im new at this lol and iv aslo heard that I need to replace the head bolts because they stretch the threads when you over heat and take the old head off
                91 318is
                94 accord
                • Austin30
                  • 61
                  i see a VR head gasket set but not a Goetz set. Goetz just has the head gasket. i want the whole set but don't want a crappy head set. is VR gasket set crap because people are giving them bad reviews
                  91 318is
                  94 accord
                  • kwill22
                    • Apr 2009
                    • 962
                    Usually if you talk to blunt he'll out a kit together for you with the goetz gasket. The profile gasket is the rubber gasket that sits between the top and bottom of the timing case covers
                    DENY IGNORANCE!
                    Schwarz 325-totaled
                    • kwill22
                      • Apr 2009
                      • 962
                      http://www.penskeparts.com/DiagramsM...8&rnd=03192010
                      Number 4 in the pic is the profile gasket
                      I personally have never had an issues with the victor reinze head gasket but I've had issues with there other gaskets. Mainly vale cover and intake manifold gaskets.
                      DENY IGNORANCE!
                      Schwarz 325-totaled
                      • Austin30
                        • 61
                        i think im going to buy the VR gasket set and buy the goetze head gasket and sell the VR head gasket it self on here. Im buying head bolts from this site ill put the link on here to see what yall think about them but one more question to wrap it all up. do i need to buy head bolt washers or will the stock be fine.
                        here is the link to see what yall think about these head bolts
                        link:
                        http://www.ecstuning.com/BMW-E30-318...Bolts/ES18254/
                        91 318is
                        94 accord
                        • roguetoaster
                          Biggus Tippus
                          • 7830
                          link:
                          Good call on getting the Goetze HG. Probably paranoia in doubting the VR gasket, but some of their stuff just seems off.
                          As far as head bolts they appear to be the correct ones, however shipping can be brutal from ECS. I suggest you go to a site such as authoausAZ or another that has free shipping on orders over an amount (usually $50) to get plain jane parts.
                          You can also reuse the washers AFAIK.
                          • Gerta
                            • Sep 2009
                            • 2119
                            Austin - there are a number of places to get parts and information on what should be done. At a minimum if you are replacing a worn head then: new goetz gasket, bolts, reuse the washers as you intend to do. How is the timing system look? Are the sprockets pointy? Has the tensioner been replaced? To remove the head you are going to need all new timing cover gaskets and should probably redo the profile gasket ... I just redid my M42 top and bottom. I ordered a top and bottom gasket kit from blunttech and had them include the goetz gasket along with the order (I have a VR headgasket you can have for free). Take a look at the links below and they offer some solid advice for any M42 owner.
                            R3Vlimited has a more active forum and BMWMan91 is a form mod/siteowner of M42club.com ... you can learn alot by searching through those forums on here and on M42club.
                            A good resource: http://www.esatclear.ie/~bpurcell/31...kforwhenbuying
                            also www.m42club.com.
                            • kwill22
                              • Apr 2009
                              • 962
                              All that minus sprockets should be included in the kit he's getting. It's just victor reinze is sketchy sometimes. Unless you're goning Ono do your timing system at the same time which is how I did mine about 2 years ago. If you have the time and money it be easier to do it at the same time
                              DENY IGNORANCE!
                              Schwarz 325-totaled
