M42 Thermostat
  • dr.gonzo
    • Nov 2009
    • 206
    M42 Thermostat
    I've completely overhauled the cooling system and the current thermostat keeps the car close to the 3/4 mark no matter the time of day or temperature. I'm not sure what size thermostat is needed but I wanted one that would be significantly cooler than stock to handle AZ summers.
    I also am not sure where to look for a lower temperature AUX fan switch.
    Thanks
    www.roadreview.net
    Something isn't right. Either the gauge is lying, or the engine is running hot. A check of the temperature of the cylinder head when the gauge is reading 3/4 will tell where to look.
    Did your "complete overhaul" include the radiator, expansion tank, cap, fan clutch, thermostat (88C), water pump, and all hoses?
    • dr.gonzo
      • Nov 2009
      • 206
      I have replaced:
      Aux fan, Fan clutch, Radiator, waterpump, and thermostat. I had the work done by Bavarian Workshop in West Hills, CA (Very reputable shop). They originally had installed a bad thermostat and I have a feeling that they replaced the bad one with a higher temp one because even with the heater on, driving on the highway, at night, it stays at 3/4s and wont go past it. I'm considering removing the thermostat later (Or drilling a couple extra holes to help the flow) later today
      www.roadreview.net
      • vpilarrt
        • Jun 2006
        • 2096
        Fan clutch and/or bleed.
          The best course of action would be to use an IR thermometer to find out how hot the engine is really running. But if you want to blindly throw parts at the problem while hoping for a favorable outcome, get a new OE 88C thermostat and put it in. Then make sure you fully bleed the cooling system.
          • dr.gonzo
            • Nov 2009
            • 206
            Isn't it obviously a thermostat if it is maintaining the car at a specific temperature no matter what? The thermostat is regulating the cars temperature at 3/4
            www.roadreview.net
              Not necessarily. It could be that there is a fault in the gauge, it's sensor, or the wiring. Or it could be that the wrong (or faulty) thermostat is installed. The temperature of the head will tell which it is.
              • dr.gonzo
                • Nov 2009
                • 206
                I removed the thermostat, drilled six holes in it (a little overboard) and put it back in. Now the car isn't coming up to proper operating temperature. Where can I get an 80C thermostat for an m42?
                Sent from my SGH-M919 using Tapatalk
                www.roadreview.net
                • Nick_S
                  • Apr 2011
                  • 3658
                  Anywhere should have an 80C thermostat. I got mine from Pelican Parts. Mine was reading 3/4 mark before I bled the system even with an 80C. After that, right in between 1/4 and 1/2
                  91 318is M50 swapped
                  05 Honda Pilot
                  24V swap thread
                    The M42 engine wants the stock 88C thermostat. Obviously you could get it from a dealer, but there are many other sources (local auto parts houses or on-line retailers).
                    • bmwman91
                      • Oct 2004
                      • 3134
                      Yeah, the 88C thermostat is the correct part. If you are getting hotter than that, there is something else wrong. Are you installing it backwards? A number of people make that mistake.
                      Transaction Feedback: LINK
                      • dr.gonzo
                        • Nov 2009
                        • 206
                        Would this thermostat work? http://www.pelicanparts.com/cgi-bin/...2531%2529%2520
                        www.roadreview.net
                        • roguetoaster
                          Biggus Tippus
                          • 7830
                          Originally posted by dr.gonzo
                          It might, but you really want the 88 degree M42 thermostat, P/N 11-53-7-511-580. Whichever brand you want should be fine, but make sure it includes the sealing ring.
                          Link on Pelican
                          • dr.gonzo
                            • Nov 2009
                            • 206
                            Link on Pelican
                            I want a a 80c one only because of the summers here
                            www.roadreview.net
                            • kwill22
                              • Apr 2009
                              • 962
                              88 will be fine. Mine doesn't go above the half mark in summer. Granted your summers might be a tad hotter than mine I'm not sure but if your cooling system is running as it should you'll be fine.
                              DENY IGNORANCE!
                              Schwarz 325-totaled
                              brilliantrot 318i-daily
                              Originally posted by mkcman17
                              don't think your hamster wheels are fast now. you will still have to give up when trying to pass that V6 odyssey to make your offramp.
