Unplug ICV?
  • RedReplicant
    • Oct 2009
    • 270
    Unplug ICV?
    What should the car do if I have a bad ICV and I unplug it? The idle varies a little bit occasionally with it plugged it and if I unplug it the car idles at 1k-ish perfectly with no variation. Bad ICV or is it something else?
    Thanks.
    91 318is - Gone
    16 VW GTI
    07 Aprilia Tuono
  • bmwman91
    • Oct 2004
    • 3134
    Sounds like it is dirty. Clean it out with some rubbing alcohol.
    Transaction Feedback: LINK
    • RedReplicant
      • Oct 2009
      • 270
      Well, if the big tube that comes out of the intake accordion goes to the ICV then I think I found my issue - it doesn't change idle when sprayed with starting fluid but I'm fairly sure the cracked tube is allowing unmetered air in regardless - I could be wrong.
      I'm assuming I can run a tube directly from the intake accordion to the bottom of the ICV and leave the cracked tube in place to continue running coolant through the bottom until I have the time to do the full intake manifold mess cleanup.
      91 318is - Gone
      16 VW GTI
      07 Aprilia Tuono
      • bmwman91
        • Oct 2004
        • 3134
        Yeah, you can run a tube straight over. I do because the stock molded rubber hoses are crap and just break open causing vacuum leaks. Same goes for the PCV hose from the valve cover.
        • RedReplicant
          • Oct 2009
          • 270
          Thank you :) I'll give it a shot tomorrow and see what happens. The idle issue is pretty intermittent so it's not a real 'issue' yet. :)
          91 318is - Gone
          16 VW GTI
          07 Aprilia Tuono
