E30 won't start but cranks.
  • oz318i98
    • May 2014
    • 4
    Hey all,
    First time e30 owner and poster.
    Have recently picked up a 318i 1998 manual coupe! drove 2000km to get it!
    Anyway...
    Was driving it the whole 2000km and a few hundred to and from work no problem. New battery and i drove it home form work one day and went to go out about 3 hours later and no go.
    Cranks well and hard because of new battery.
    But zero on the starting. i have been regularly trying and it hasten changed except for one bit were it "coughed" slightly but nothing else.
    So far i have checked my fuses.
    All looks to be good.
    Taken out my seat and cannot here the fuel pump do a thing when i turn the key.
    I disconnected the fuel like from the regulator to the fuel rail. ( I think )
    Spilled a bit of raw fuel and then cranked it and nothing came from the fuel again. Still drips a little.
    The only weird thing i can hear is a electrical humming when the key is in the on position coming from right underneath the manifold closer to the firewall?
    Is this normal.?
    Before the car died it made a similar to low oil ticking sound from the manifold but was not low oil as i topped her right up? Coincedence?
    Anyhelp or insight as to previous problems or things to check next would be greatly appreciated.!!
  • TobyB
    • 5298
    If it's not pumping fuel while you're cranking, it's a safe bet to replace the fuel pump.
    The definitive test would be to put a test light on the fuel pump leads- that would rule
    out the fuel pump relay, too.
    hth
    t
    • oz318i98
      • May 2014
      • 4
      Hey Toby,
      Thanks for the reply.
      What leads are these? Whats specs should i look for on a multi-meter when testing this? (voltage?)
      • cunninglinguist
        • Mar 2004
        • 281
        Also check connectors to the fuel pump itself. They are known for coming loose.
        • Vivek
          attention whore/retard/bitch
          • 6167
          Give your fuel pump a good whack from the top. If that works, then your fuel pump is dead/on it's way out.
          1992 Mauritiusblau Vert
          2011 Alpinweiss 335is coupe
          2002 540i/6 Black/Black
          2003 GSX-R 750 (RIP)
          • oz318i98
            • May 2014
            • 4
            Cheers for the info lads!
            Cunninglinguist : All the connections seem to be fine.
            I have bought a test light/screwdriving looking light up handle thingy me-bob to test the relay if need be.
            Is there a fuse near the pump i think i read somehwere?
            Pretty sure all the fuses in my fuse box were original. Except one fuse that looked modern.
            • Vivek
              • 6167
              Off the top of my head fuse #11 is the fuel pump and #9 is fuel delivery, not quite sure what that is. There's also a fuel pump relay. I have not heard of a fuse near the pump.
              • oz318i98
                • May 2014
                • 4
                Hey Viv,
                Cheers very much for the whack it with a hammer trick.
                Thats what i did, and tried to start it and it spat fuel everywhere. I hooked it back up started the car and then let it run for a bit. After that she didn't want to start haha. Fuel pump is out now and picking up a replacement tomorrow! Cheers for all the responses and insight guys!
